3 restos WIP = psycho
kenikh's Avatar
Valve springs - can you tell visually if they are stock or stronger?
Here is a valve spring off of my bench motor, still in the head. I will remove them soon to measure if they are in spec, but is there any way to tell if they are higher spec than stock without testing their tension?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-26-2006, 08:37 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Porsche factory springs are the only spring that have a progressive winding. tighter at one end than the other.
If your spring has a progressive winding it is a factory spring. If it is not progressive it is an after market spring.
The spring in your picture looks progressive.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-27-2006, 05:32 AM
kenikh's Avatar
I can't really tell if these are progressively wound or not; the springs are too small, unlike shocks. I will say in looking at them the coil gaps look pretty uniform.
I should be able to take a caliper and measure the outer coil gaps to confirm. Would this be a reliable way to check or is the only real way to check with a valve spring tester?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-27-2006, 07:07 AM
Just look more closely at the spring. I may be mistaken (rarely happens ) but that spring looks progressive to me.
Look at the ends of the spring where they are ground flat. The angle of the coils at that point look different.
Coils closer together at one end.
Henry Schmidt
Ph: 760-728-3062
Old 04-27-2006, 08:13 AM
Irrationally exuberant
ChrisBennet's Avatar
Are they blue-ish? My AASCO valve springs are blueish.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-27-2006, 09:15 AM
kenikh's Avatar
They are indeed bluish. Henry, I'll take a closer look when I get home to confirm the details you were looking at.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-27-2006, 09:29 AM
