shbop's Avatar
2.0 head comparison
Can anyone tell me about the 69' 2.0 T heads. Specifically if the combustion area is the same as 66' 2.0. I've recently acquired a set of 69's and I'm considering whether or not to put them on my 66' 2.0 re-build. I'm using 81mm JE's @ 9.5:1. Weber's for induction. I realize I'm not building a rocket-ship here, but the larger valve heads have me thinking. Thanks in advance for any help!
Jon
Old 05-05-2006, 10:46 PM
jluetjen's Avatar
I believe (working from memory) that the '69T heads will have bigger valves then the 66 heads. These will provide a performance improvement. As far as the dome shape, I believe that it's pretty much the same.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 05-06-2006, 05:03 AM
shbop's Avatar
John, Thanks for the reply. Do you think it's worth the effort? The ports are the same size on both:32 But the 69' has larger valves: 42/38 vs. 39/35
Jon
Old 05-06-2006, 07:44 AM
Try not, Do or Do not
Henry Schmidt's Avatar
BIGGER VALVE ARE WORTH THE EFFORT.
Go ahead and port the heads a little (35 or so) , even if they end up larger than the intake manifold.
If you still have the original 66 911 (Solex) cams they love to breath.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-06-2006, 02:06 PM
shbop's Avatar
That's what I was hoping to hear. Thanks Henry!
Jon
Old 05-06-2006, 05:03 PM
