Wil Wil is offline
911 SC engine/trans separation problem
911 SC engine and trans out of car. 4 nuts off, trans. won't slide off engine. Do I have to remove clutch lever, circlip, and 2 springs in order for the trans to slide off studs? somethings hanging it up. thanks.
Old 05-13-2006, 06:37 AM
dtw dtw is offline
GAFB
Yes.
Several BMWs
Old 05-13-2006, 07:04 AM
Yes,
The clutch fork shaft has to be able to rotate about 45 degrees as you pull the tranny off.
-Andy
Old 05-13-2006, 10:51 PM
