911 SC engine/trans separation problem
911 SC engine and trans out of car. 4 nuts off, trans. won't slide off engine. Do I have to remove clutch lever, circlip, and 2 springs in order for the trans to slide off studs? somethings hanging it up. thanks.
GAFB
Yes.
Several BMWs |
Yes,
The clutch fork shaft has to be able to rotate about 45 degrees as you pull the tranny off. -Andy
72 Carrera RS replica, Spec 911 racer |
