I have the Curil T and Loctite 574 already, but came across this thread and thought since I haven't assembled the motor yet I might as well take the advice of the experts in this thread. Well, maybe not all the "experts"... |
Same list as previously posted by others, except I added the return tube o-ring lubricant as recommended in one of Henry Schmidt’s previous posts.
Outer Case Halves: Threebond 1104 (now 1184) Bearing Saddle Surfaces: Loctite 574 #8 Bearing (balancer end) O-Ring: Threebond 1211 (now 1215) Case Thru Bolts: Dow Corning 111 on Green Viton O-Rings Flywheel Seal: DRY Balancer Seal: DRY Intermediate Shaft Cover to Case: ThreeBond 1211 (now 1215) Oil Breather Cover to Case: ThreeBond 1211 (now 1215) Cylinders to Case: Curil K-2 or ThreeBond 1211 (now 1215) Cam Towers to Cylinder Heads: Threebond 1104 (now 1184) Cam Chain Housings to Case: Threebond 1104 (now 1184) Cam Chain Housings to Cam Towers: Threebond 1104 (now 1184) Cam Chain Housing Cover to Cam Chain Housing: Threebond 1104 (now 1184) Gaskets: Thin coat of Loctite 574 Oil return tube O-rings: Dow 55 o-ring lubricant (alternate: Dow 111). |
I've found an alternative to Threebond 1184 which is Aisin AB1184A. MSDS sheet says its made by Threebond, so should be good there. Question is, for the areas that call for 1211 or 1215, is 1207 or 1281 a viable alternative, or do I just use the Curil T that I already have? Both the 1207 and 1281 are readily available as they are the Aisin brand manufactured by Threebond. |
Looks like 1207 might work, except that its tack free in 3 minutes vs. 40 for the 1211. 1215 has a 20 minute tack free time.
The other difference is that the 1211 and 1215 are Oxime solvent, 1207 is Acetone. First preference would be to use the exact products recommended, but as I mentioned, Threebond is currently unavailable in Canada, so need to look for the rebranded equivalents. |
http://forums.pelicanparts.com/uploa...1613492708.gif Many thanks |
I've used a light coating of Curil-T on both sides. Keeps the gasket in place during assembly and prevents weeping during engine heat cycles.
The point of using the sealant on the paper gasket is not only to give it some additional sealing ability but also to give the gasket some wiggle room to settle in place as you’re physically assembling the parts. This paper gasket can sometimes get pinched as you’re pushing the cover plate (actually called a thrust plate because the end of the camshaft can push against it during engine operation) home into the chain housing. So you definitely want to look around/behind the chain housing after installation to make sure the gasket didn’t get pinched or folded upon screwing down the thrust plate.
People have also recommended other sealants on this paper gasket like Permatex copper spray, Curil T green goop, and the famous Loctite 574 orange goop. Whatever works. Just don’t use silicone sealant, PLEASE! Again, the purpose is additional protection against a leak. I don’t like anything too sticky because sticky makes it more likely for the gasket to get stuck in a bad position. You want the gasket to have a little bit of ability to settle into place. But of course you don’t want it to squish out of place either! I have personally encountered this leak on one of my engine projects and it’s a big disappointment to have. It’s a lot of work to correct the leak and therefore you absolutely want to avoid it happening My opinion is the gasket is supposed to be fine without sealant. That’s the whole point of the gasket- to seal. The challenge here is that the “snout” on the end of the camshaft housing is not always fully flat. I have leveled the snout on several cam housings via a flat plate and wet sandpaper which has shown me some spots on the snout are very narrowly flat with the rest of the surface. Therein lies the problem and I feel the problem should be addressed at the sealing surface to ensure the best seal. Just my opinion and to each his own, as the saying goes It’s very easy to level the snout surface. All you need is a good flat surface, some tape, some wet sanding paper (400 or 600 is fine, no need to make it super smooth) and a sharpie marker to color the snout for use as an indicator of your sanding progress. You’ll see right away how flat, or not, is the snout after just a few swipes of the snout across the paper. |
I'm having difficulty locating Curil T.
However, I see Curil T2 is commonly available. Is Curil T2 replacing Curil T? |
To quote: "Its [sic] called CURIL T2 and this name replaces the old designation of Curil K2 and Curil T sealants." |
I could have missed it, but any sealant recommended on the gaskets for the chain tensioner covers?
A very light tacky coat of Curil-T works quite well. Just enough to make the gasket look shiny is all it takes.
This works really well. Coat both sides of the gasket. I do this on all paper engine/transmission gaskets. |
Just another set of data points from my recent 3.2 to 3.4 rebuild. Grateful for all the good information on this thread and to no longer have any oil on my garage floor.
Sealants: Case perimeter: Threebond 1184 Case webs: Loctite 574 Through bolt o-rings: Molykote + tiny amount of Hondabond 4 on washers #8 Bearing: Threebond 1211 Cylinder base shims: Curil-T Heads to cam towers: Threebond 1184 Oil breather gasket: Hondabond 4 Chain housing to heads: PFTE grease on o-Ring, Hondabond 4 on gasket Chain cover to case gaskets: light Hondabond 4 Chain cover gaskets: dry Oil return tube o-rings: Molykote Int Shaft cover gasket: Hondabond 4 failed, switched to Loctite 574 with new gasket. Rear Main seal: Installed dry outer edge, light PTFE grease on inner to prevent burning on initial startup. Leaks and fixes (none of the leaks were enough to even cause a drop on the floor):
(new on right) http://forums.pelicanparts.com/uploa...1667058149.jpg http://forums.pelicanparts.com/uploa...1667058149.jpg http://forums.pelicanparts.com/uploa...1667058149.jpg |
Outstanding, enjoy your New 3.4L, she will feel 700 lbs lighter :-)
Thanks for the excellent update @thetorch
Curil T and Curil T2 are different formulas. T2 is higher temperature and lower viscosity.
We still use the "T" because it seems to stay in place better and temperature resistance is more than adequate. Many new products offered by manufactures as "new and improved" are in fact just environmentally compliant. 1104 was replaced because of lead content not performance enhancements. Curil "T" was replaced to eliminate "undesirable solvents". I guess they could have kept it with a Millennial safety warning "not for human consumption". Maybe much like Tide pods. |
https://www.amazon.com/Elring-non-hardening-temperature-resistant-sealing-compound/dp/B01N0X8M8G/ref=sr_1_1?crid=2K0ITTVX7SRX1&keywords=curil+t&qid =1667344977&qu=eyJxc2MiOiIwLjc5IiwicXNhIjoiMC40OCI sInFzcCI6IjAuNTEifQ%3D%3D&sprefix=%2Caps%2C198&sr= 8-1 |
item got stuck in post in poland.. she said she would refund... never did... too much time had passed and I was not eligible for refund. |
for the record, I bought Curil-T on Amazon delivered to CA no problem.
There are carburetor cleaners sold on Amazon that clearly state "Not for sale in California" that regularly get shipped to California. Now, try to buy a toilet with a 2 gal tank....forget about it:confused: |
One builder suggested using black Permatex silicon on the thru bolt blue seals. Any thoughts?
In my next most perfect life somebody is going to put a chart together grouping all these products keyed to Waynes bible. __________________ |
I wonder why Wayne's rebuild book says to spread it on the right side? On page 133 it shows a picture with the sealant applied - side mounted to engine stand with studs in it.
Is there are reason he specifies it this way? Also, how do you know how the factory did it? (not being a jerk - just curious) |
^^^^ this.... :) Its a decent book, but a "bible" it is not...
Just got this from Admins ref a response I made to a for sale ad by a known Pelican; “Boxster Brake kit F/R the seller is not always active on the forums but you contact the him at deyecrest@gmail.com if youre still interested” |
Yes, Have noted him as a TROLL...
I'm a new registered member and inquired on a set of wheels. I got the same PM from Admins referring me to deyecrest@gmail.com |
To add a bit more detail to the scammer's MO.......
Go to the top of this page and then the pull-down Menu " Search this thread". Put "Black" as the word in your search. Interesting what shows up as the very first post 06-29-2008 concerning Black Silicon. |
Imagine if these people put as much effort into doing something legitimate as they do to running scams, they just might make a difference in this world. |
More than likely a probing attempt to get in through the backdoor of Pelican or an attempt to see if a phishing scheme could be generated to attack individual Pelican subscribers.
There's a Dow sealant for O-rings, Henry Schmidt offers it for sale, along with the others noted here. Also, Viton (green) versions of these are the ones to use.
Mods, adminss is a Bot. Please Ban.
Post #42 from this thread. Bot, please ban. |
New build and I have a very small leak at one of the top through bolts (nut side) at #4 and a heavier leak at #5. No other issues. I used Dow Corning 111 and green viton o-rings during assembly. I want to reinstall new orings but am wondering if I should try a new sealant, such as Permatex RTV Wayne mentions in his book. Maybe there was a small scratch or something that requires additional sealing properties. Thoughts?
I'm in the NO RTV in a flat 6 camp. It's one of Satan's bodily fluids.
To date I have never had one of the through bolt o rings leak. It sounds like you could have one of a few things going in: - when tightening, the washer rotated and cut the o ring. - when the o ring was installed over the threads, it was cut - the underside of the washer might have debris from previous build that was not cleaned. - case spigot surface is compromised, not flat, or has debris remaining from prior build. Sorry this has happened to you. But looks like you gotta pull it all out to double check. |
"the Watson"
Top or Bottom studs? If top, you should be able to get access by removing alternator and releasing the tin deflector. Replace o-rings, and re torque. If bottom bolts, you have more work to do... NO to RTV..... Cheers |
| All times are GMT -8. The time now is 06:37 AM. |
