-   -   The Complete Engine Sealant Thread... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/284737-complete-engine-sealant-thread.html)
Bluetarga78 09-30-2025 01:07 PM
I wasn’t sure if my question pertaining to using silk thread as a gasket material embedded in the loctite 574 was relevant in this thread so I started a new thread. Also, not trying to steal any thoughts here, just a different approach I was asking for advice on.
Turbo_pro 09-30-2025 04:45 PM
My only concern with using silk thread is deterioration. The 574 will harden but the thread will not. The thread could affect the clamping force of the bolts reducing predetermined force required to prevent case shuffle. As the aluminum expands and contracts with heat, the thread can compress. If this compression allows for excess movement, the 574 can crack. All speculation but that's my guess.
I am not an engineer so take it for what it's worth $.02.
dannobee 10-01-2025 08:19 AM
Literally billions and billions of engines have been built from all manufacturers around the globe using some version or copy of ThreeBond grey RTV. It's been proven over decades of use with very low incidents of warranty claims. No need to try to reinvent the wheel or use materials and procedures from the middle of the last century (aircraft).
Use the tried and true materials and procedures outlined in this thread. Especially when considering the labor involved in repairing a leak at the case halves on one of these engines.
85RedCarrera 10-02-2025 05:53 AM
The primary issue that I have with some silicone products on aluminum is when it’s time to remove it- so I don’t use some products anywhere I might be going back into anytime in the ‘foreseeable’ future. Most Silicone on steel is no biggie- just get a brass brush and it’ll all come off.
Dirko required Digesil (best product ever for removing all traces of silicone) to Get it completely off the aluminum. Acetone was useless.
On my Ducatis, the Threebond type products are easy to remove- and then Acetone removes every trace of it. Not so with the Dirko- extremely tenacious stuff…. And I expect that that is desirable, as the bead after squeeze out inside the case seems firm and well adhered, so that it won’t sprout legs and walk through the engine.
I must admit though, getting the squeeze out with Dirko exactly where you want it to be, depends on the flange width and the amount applied, and I am used to using the Threebond type products on narrow flanges, and you don’t need much product at all in that scenario.
The first Porsche case I sealed with Dirko could have used a bit more than I applied, as I was just a hair less than the squeeze out that I wanted. It’s cleaned up now and I’ll be sealing it again soon. Next time I use Dirko I expect I’ll get it just right. Using New products sometimes require a practice session..!
00 Scrub 10-04-2025 09:30 PM
What are people using to seal the crankcase vents (the opening covered in green tape) on GT3 blocks? I was planning to use Hylomar M. Any reason not to and use a silicone instead?
http://forums.pelicanparts.com/uploa...1759638584.png
CBRacerX 11-11-2025 09:52 AM
Originally Posted by JoeMag (Post 12478816)
I think you're always going to get some squeeze out. You're probably squeezing out 80% of what was put on the surface. Clearly not the experience of Henry... I've rebuild my motor few times, put threebond 1184 on one case half (basically completely cover the one surface). Some may run down inside of case (maybe I applied too much). These few streaks (not large rivers) have stuck to inside of case (if case is very clean, it should, right? the surface is quite rough so lots to bond to). It takes work to get them off when you split case again.
Unplanned squeeze out test https://forums.pelicanparts.com/911-engine-rebuilding-forum/302345-sealing-case-experiment-so-you-dont-have.html
Brookieslayer 11-23-2025 04:33 PM
Dirko replacing 1186
Originally Posted by Henry Schmidt (Post 12456479)
Over the last 18 months, we have been doing some in-house testing of hi temp Dirko Grey.
So far the results are good.
Elasticity, elongated breakaway and chemical resistance is impressive.
The shear strength is better than ThreeBond 1184 and the tensile strength is comparable.
Pressure @ .080" gap is better than ThreeBond or Loctite 574.
Good Evening,
Henry are you replacing 1184 with the Dirko Grey in your kit now? Or is the 1184 still the kit staple?
Thanks for your contributions to the community.
Henry Schmidt 11-23-2025 05:52 PM
Originally Posted by Brookieslayer (Post 12567975)
Good Evening,
What we use in-house is Dirko HT but for those customers committed to the TB 1184, my kit can ship with either product. Customer choice.
Brookieslayer 11-23-2025 06:51 PM
Thank you
Thanks Henry. Appreciate the information.
