I thought gaskets were installed dry. So is the consensus dry or 1184 or 574? |
As a general rule, if a gasket may need to be changed or the thermal characteristics of the surfaces require movement, we use Curil "T" If the surface is stable and not likely to need replacing anytime soon, a very thin coat of 574 is applied. |
D. |
Thanks Henry.
Am I correct that 574 would be preferred over 1184 for the air breather cover? This does not seem like an application where a lot of movement would be occurring for the surfaces?
Hey Ed! Great to hear from you! Thanks for the info, now just waiting for the 574 to arrive so I can wrap up my project.
How about a recommendation on the plugs on the cam tower. The ones on the forward end as installed on the engine. To clarify, the same diameter as the cam bearing.
We use 574 there as well.
Cheers |
Thank you Jeff.
The only issue I encountered were a few rocker shafts that "walked", and even with the RSR seals, leaked until I finally got them right.
sounds like a legit account for sure... ;) |
How hard is 574 to remove if you have a leak and need to redo a part you used it on? Say the chain housing to case area?
Main bearing web surfaces should be nothing.....
Clarifications and Updates
I have spent my Sunday morning skimming all 37 pages of this thread. Thanks to Henry Schmidt, CBRacerX, Wayne 962, and others who have contributed. A few questions as I am near assembling our 914-6 (aka 1969 911T) engine in 2023.
Are folks putting rubber grease on the oil pump seals?
| All times are GMT -8. The time now is 02:13 PM. |
