adomakin's Avatar
ill be running a J+S safeguard on my street engine. it seems like a no brainer to me, even for a street car. i wont be boosting much past 1 bar, if at all, but if it saves my engine then its worth its weight in gold (literally!)
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 06-15-2006, 12:46 PM
J&S recommends that their unit is threaded into the case in a central location. On the four cylinder applications I've just tapped a hole in the bell housing, since that doesn't involve having to have the case apart for something that protrudes into the case near internals. They also were originally introduced especially for aircooled engines, even with all the "noise", so there's no problem there- some people believe you can't run a knock sensor on an aircooled engine! They just haven't seen any late model 911s and the factory knock sensor bridges. :-)
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 06-15-2006, 03:06 PM
Forced Induction Junkie
WERK I's Avatar
Aren't most aircraft engines equipped with knock sensors? Is their cost prohibitive?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 06-15-2006, 03:16 PM
That's a good question. I didn't think they did. I know nothing in the experimentals I have dealt with do.
Charles Navarro
Old 06-15-2006, 03:37 PM
Dave:
Aircraft engines generally use two magneto's so they are self-contained redundant ignitions that will run the engine without any electrical system.
No knock sensors on any Lycoming or Continental 4 or 6 cylinder that I've ever seen or flown behind,...
These all use twin-plugs with each magneto firing one plug in each cylinder.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-15-2006, 09:54 PM
WERK I's Avatar
Steve and Charles, thanks.
Dave
Old 06-16-2006, 06:52 AM
Me like track days
Craig 930 RS's Avatar
Initial verdict (not mine, local shop(s)) on some of the parts - P&Cs:
The short skirt pistons are known to slap and scrape a bit - just as the ones in this 930 did. We could almost call this 'normal' - for a short skirt.
Long skirt Mahles are going in.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-19-2006, 02:32 PM
MBruns for President
JeremyD's Avatar
You still looking for an andial fuel enrichment? saw this on PCA site and thought of your woes - no affiliation just trying to help a brother out...
Link to Fuel Enrichment
Brand new Andial Fuel Enrichment Kit. Never removed from packaging. I am keeping my car stock. $450 (25% off wholesale). I have other 930 performance parts for sale.
Type of Seller: Private Seller
Company:
Street Address:
City: Naples
State/Province: FL
Zip/Postal Code: 34105-4526
Country: United States
Old 06-19-2006, 07:50 PM
Me like track days
No, I've solidly learned that the system isn't a good idea - but I do thank you for the help!
Old 06-19-2006, 08:39 PM
Me like track days
Moving on to the build process!
Ni resist rgrooves have been cut:
Crank actually looks pretty good - will only need a polishing, even after the spun bearing. One scratch, but the bearing shell covers it and is not a *raised* gouge:
Old 06-21-2006, 12:27 PM
frencjas's Avatar
Craig,
I saw your car at the shop... MAJOR bummer! Hopefully you'll be back in action soon!
Jason
Jason
Keep Right Except to Pass!
2000 Audi S4 Quattro Non-Sunroof
1989 BMW M3 (sold 12/06)
1977 911S Wide Body 3.6 Varioram (sold 11/05)
Old 06-21-2006, 10:30 PM
Stranger on the Internet
patkeefe's Avatar
Craig:
Did you do an oil analysis on the drained oil? I would guess from the pictures that you were running excessively rich at some point in the RPM range, but were too lean at the points of obvious detonation. The bearings look like a case of fuel diluted lubricant, as do the distinct band of scored areas of the cylinder walls. I can only guess that you couldn't hear the detonation at the track because of road noise and the helmet. The signs of detonation are not as obvious or severe in the chamber pictures. Please keep in mind that I am by no means any sort of expert in this matter (I likely couldn't carry the bags of most of the posters here), but have seen many of the forced induction VW derivative air cooleds in this exact same condition. This may be more of a pre-ignition condition than true detonation. I also wonder of the effects on timing with the higher overlp 964 cam you have.
The knock sensor is a great idea, which I will try to put on my little SC turbo project. Good luck with the rebuild.
Pat
Patrick E. Keefe
78 SC
Old 06-23-2006, 06:47 PM
Me like track days
What the he** caused this?
#6 cam lobe was apparently very worn (it was ent off for repair, did not see it), and BOTH #6 rockers look like crap - 3 distinct flat spots on each one.
WHY?
Old 08-01-2006, 12:53 PM
CBRacerX's Avatar
Oil sprayer bar failure.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 08-01-2006, 01:03 PM
better pull the spray bars out and clean them real well. amazing that the crank journal survived the spun rod bearing. i've never seen one live. the journals can look ok, but a mic says different.
206 637 4071
Old 08-01-2006, 01:16 PM
frencjas's Avatar
Hmmm, the plot thickens...
Say hi to my S4 next time you're at R.E. visiting your car. I think yours is the only one there in the shop longer than mine (if it's still there)
Jason
Old 08-01-2006, 01:36 PM
Me like track days
I wonder if the #6 rod material made its way to the spray bar - possible?
Old 08-01-2006, 01:42 PM
WERK I's Avatar
If you had any coking in the oil, it is possible that can clog the spray bar.
Dave
Old 08-01-2006, 05:32 PM
Author of "101 Projects"
Wayne 962's Avatar
Sorry guys, but I'm thinking that a large contributor to this failure was a distinct lack of oil pressure. I would check the case oil pistons and their respective bores to make sure they are working properly. You just don't see this type of damage with oil running around in there, even if the engine gets hot.
-Wayne
Old 08-01-2006, 08:40 PM
CBRacerX's Avatar
Great point Wayne, I was thinking this was localized damage to a single cam lobe (wait, isn't that what this is?). OK, I stand by my clogged spray bar theory
Chris
Old 08-01-2006, 08:50 PM
