Ps&Cs - source for new - reasonable $$$ for 964, 3.6??
Who has the best price to value ratio for new pistons and cylinders for a 964, 3.6 bottom end?
I'm questioning if finding good quality used ones will end up with the results I'm seeking. I just can't fathom buying new ones for more than $3k, though. Should I consider re-honing the factory cylinders and fitting new, oversized pistons like JEs? Are there other reasonably priced options? The engine details are 964 bottom end: crank, pistons, rods, 993 heads, solid lifter cams 993 Super Sport Cam profile, '95 993 engine management and intake. 993 Heat Exchangers and sport exhaust. Thanks much in advance for the advice! Doug
1971 RSR - interpretation |
Doug, send them to EBS to get replated and buy a set of JE pistons, total should be in the 2k area........
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Irrationally exuberant
I bought a set of used late style 964 P&C for $1000 from Kevin Roush back in 2004. I was a little nervous but the client who bought the rebuilt motor said the motor didn't smoke or use oil from the beginning. Frankly that is hard to believe but if it's true you couldn't ask for more from a used set of P&C.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 06-07-2006 at 05:10 AM.. |
Thanks and good advice from you both!
What would be the minimum price for new? Thank you, Doug
Contact Walt at Competition Egineering. I bought a set of used early style P/C's for a very reasonable price. He machined the groove for a head gasket. So far I clocked 16.000 miles on the rebuilt engine and they are perfect. No oil consumption and no head leaks.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Doug, Rennsport Systems also can machine a groove on a early set of cylinders. They machine a step for the 993 gasket to fit and the price is pretty reasonable too! They did a set for me a while ago and I was pleased with the result. Sounds similar to what ingo had done. This may help broden your search for replacements.
Cheers
Guys,
Thanks for the additional information. I followed up with Walt. In parallel, I found a set that my friend Jeff Hine recommended. One of the guys at Chris's German in the PNW had left-over. They are low-mile, late 964, are in-spec and on their way. Hopefully, this info may help out future seekers. Doug
1971 RSR - interpretation Last edited by DW SD; 06-08-2006 at 10:14 AM.. |
The guys at Chris' are good folks. They helped me out of a jam when I was down there way for a track day last year.
Cheers
