Jeff Alton's Avatar
Which spark plug??
What plug should I use in this motor.
3.4
Twin plug
10.5CR
mod S cams
ITB's
headers (1 5/8)
www.turn3autosport.com
Old 06-06-2006, 05:18 PM
3 restos WIP = psycho
kenikh's Avatar
I assume the 2nd plug was machined standard, not undersized?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-06-2006, 05:28 PM
Jeff Alton's Avatar
Standard 14mm plug, top and bottom.
Cheers
Old 06-06-2006, 05:57 PM
Super Moderator
cstreit's Avatar
I'm really happy with my NGK's...
I can't remember the number, but I use the 14mm as well with nearly the same motor... R-587 something I think... I had to switch away from the projected tip style when I upgraded from 3.0 to 3.3L
I have some back at the garage and can check the numbers when I get back if you want.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-06-2006, 08:32 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Chris what about going 3.3 meant no preojected tip? I assume its because of the high comp pistons and clearance?
Bosch, NGK, cant really go wrong with either because you can order pretty much whatever you want from both. What setup are you using for your ignition?
74 911s neverending story. two feet and a jetta for now.
Old 06-06-2006, 09:02 PM
Jeff Alton's Avatar
I guess I should have asked about heat range! oops. I have always had good luck with NGK's but just not sure on which one for this new motor.
Cheers
Old 06-06-2006, 10:29 PM
Super Moderator
cstreit's Avatar
Pkid, it was a suprise to me too, because I had 95mm 10.5:1's prior and a visual inspection of the new piston made it look like they were the same height and dome shape. However the projected tip style were JUST hitting the plug at TDC right at the edge of the exhaust valve pocket.
The non-projected tp gave me a few mm clearance.
Jeff, I originally used the 9 heat range (which in NGK parlance is cold) but got some fouling at idle and had hard starts. I moved to 8 and haven't had an issue since.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 06-07-2006, 05:48 AM
Jeff Alton's Avatar
Chris, thanks, I would be interesred in the numbers.
Cheers
Old 06-07-2006, 08:38 AM
Navin Johnson
TimT's Avatar
Have had success with these
NGK R5671A- 8
'69 911 GT-5
'75 914 GT-3
and others
Old 06-07-2006, 01:20 PM
Jeff Alton's Avatar
Thanks Tim, so you think that would be okay with my motor configuration?
Old 06-07-2006, 01:32 PM
good timing
This thread has come about at a wonderful time. Now I am second guessing the plugs I went with. Chris are you running the 100mm JE's with 10.5:1? I currently have Bosch plugs in there top and bottom and when I checked deck height I forgot to put in the lower plugs. Silly mistake I know.
Any reason why you went with NGK over Bosch?
Jeff saw youve got the longblock together, recieved any electronics yet?
Old 06-07-2006, 02:20 PM
len911's Avatar
As a point of reference...
3.2l with 11:1 Cosworth pistons, twin plugged using Electromotive modules, cam is similar to a GE80 (but from Elgin), 1 5/8 headers, ported and 46IDAs.
Car came with NGKs BPP9Es but was fouling plugs. Ended up going to BP7ES (hotter) and it seems to run great! It is equivalent to a Bosch W5DC. Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 06-07-2006, 04:51 PM
Jeff Alton's Avatar
I run/ran NGK 7's in it when it was a 3.2 with 964 cams with no problems.
Thanks, keep the tips comming!
Cheers
Old 06-07-2006, 06:56 PM
Jeff Alton's Avatar
Chris, I put the old standard NGK's in tonight (with a very huge gap for this test) and turned the engine over a bunch of times. The piston never hit the plug, am I okay with the standard style plugs or should I get the ones like you have?
Cheers
Old 06-07-2006, 10:44 PM
Super Moderator
cstreit's Avatar
Jeff,
I'm using the same ones that TimT has above. Had great luck with them so far. (Tim, did you find them at your local place?). FWIW I get them at the local NAPA for about $1.29 apeice!
I chose NGK over Bosch because that's what Richard Clewett recommended when I originally go the Electromotive setup from him. Since they work well enough, I never saw any reason to change to Bosch, even if they are from the fatherland...
Jeff, as long as you have clearance, you're fine. In fact I'd prefer the projected tip for 2 reasons. First you lose a little more compression with the recessed version and second, the recess doesn't stick out into the combustion chamber as well so I assume ignition is a little harder. Since I switched from 95mm to 100mm I'm mixing in race gas on 90+ degree days to be on the safe side...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 06-08-2006, 06:33 AM
Jeff Alton's Avatar
Thanks guys!
Cheers
Old 06-08-2006, 09:59 AM
Addicted to Racing
edbaus's Avatar
Here is another vote for the BP 7 Es's.
Have them in both cars. Both twin pluged.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 06-08-2006, 10:11 AM
beepbeep's Avatar
Use NGK 7:s or even 6:es. 9:es are way too cold and fit for turbocharged cars running on track. They foul on street. BP7ES is OK.
Thank you for your time,
Old 06-08-2006, 01:56 PM
gumba's Avatar
I'm using a W4CS with a similar set up. 46mm Webers instead of ITB's.
On a different note, I see your looking for for an open trailer. Have you checked out this trailer place. It's in Parksville, BC. I'm looking for an aluminum trailer and their prices seem pretty reasonable.
http://www.expresstrailer.com/a-car.htm
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 06-09-2006, 07:49 AM
Jeff Alton's Avatar
Hmmm, no I had not. I will check them out.
Cheers
Old 06-09-2006, 08:26 AM
