Forced Induction Junkie
WERK I's Avatar
Originally posted by cgarr
Looks very nice!! One case half has a chanfer at the thru bolt, this is the side the nut goes on, (helps seal around the bolt thread) I put mine all in and tite without the o-rings then removed one at a time and put the o-rings on each, old 912 engine trick to keep the o-rings from grinding up when going tite, mine were also opposite the cooler too.
Excellent tip!
Has anyone ever chamfered the other side of the case to prevent the o-rings from tearing. Chris, I thought you were going to try this once on a future build. Any results?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-18-2007, 06:28 AM
Send a message via AIM to Purkinjefibre
Wink engine in car and running
Hi Vic, yes those are in for timing- now fitted with hydraulic tensioners.
Craig- that is an awesome tip- if only you posted a couple of months earlier...LOL
Well the engine is in the car and running-Tuning megasquirt is a fun experience... I'll post some more pics on the weekend,
slater
Brett
'79 SC-Silver Arrow
3.2ss-twinplug-EFI
Old 02-19-2007, 07:36 AM
I would also like to do Megasquirt someday. Keep us posted.
Old 02-19-2007, 12:10 PM
