iangray100's Avatar
Sealer for throughbolts ..should we use it?
Hi ,
Started my 964 rebuild and I see Waynes book says use RTV on the O-ring throughbolts. But I see from the recent threads , James and Kirk's that no sealer was used only Silicone 111 grease as a lubricant.
What's the opinion of others ..sealer or not or perhaps Threebond 1211 ?
thanks
Ian
Old 02-18-2007, 03:51 AM
I use dow corning 111 on my engines with no leaks. granted I have only done 4 911 engines but it has worked very well
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-18-2007, 05:00 AM
thru bolts
No sealer is advised, make sure that there is a chamfer at the hole (just enough to take the sharp edge off) so the o ring is not cut, DC 111 is good or some heavy assy. oil will work fine too.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 02-18-2007, 07:01 AM
Also a good idea to use the green viton o-rings instead of the blue silicon that comes with the gasket kits. I buy mine from German Precision but they should be available other places as well.
-Andy
Old 02-18-2007, 09:44 PM
iangray100's Avatar
thanks guys, and I have green O- rings etc as Henry shipped me a full set of gaskets over to the UK for the rebuild.
____________________
UK Surrey
Coupe 964 MY92 Tiptronic
To many toys to list..wife might be reading this ;-)
Personal thread: http://forums.pelicanparts.com/911-engine-rebuilding-forum/340187-964-3-6-full-engine-rebuild-over-uk.html
Old 02-19-2007, 11:06 AM
304065's Avatar
I have Wayne's book and think it's great but no silicone sealer is EVER going in contact with my oil system, of which the through-bolt holes are a part.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-19-2007, 04:05 PM
stevepaa's Avatar
I have the same issue with putting sealer on the # 8 bearing o-ring groove. Do not put sealer where oil flows.
steve
old rocket inguneer
Old 02-19-2007, 04:13 PM
Less brakes, more gas!
euro911sc's Avatar
Thumbs down
Hahhahaaa I love RTV...
NOT! yeah I don't think I'll ever be using RTV on an engine again... EVER. See what I found in mine (scroll down to the pic of the cam carrier... its a classic):
Holy RTV Batman!!
*sigh*
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-19-2007, 05:27 PM
