9dreizig's Avatar
Send a message via AIM to 9dreizig
turbo tuning suggestions
I just got my engine into my car. My buddy came over with his LM-1. We tuned idle to 13.5 and it seems to be running well except it's going lean on deceleration ( 15.7) is this normal he seems to think it's too lean. If so what can be done to correct it ??
Todd
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 06-26-2006, 11:27 AM
MBEngineering's Avatar
HI a little more info on the engine would not go a miss, as to just what you have and then we just may be able to help, thank you
regards mike
Old 06-26-2006, 12:30 PM
9dreizig's Avatar
OOPs, it's a 79 3.3 turbo with a K27-7200 turbo.
SC Cams .. Hope that helps
"Todd"
Old 06-26-2006, 12:45 PM
resident samsquamch
sand_man's Avatar
some good info here:
http://forums.rennlist.com/rennforums/showthread.php?t=267790
I have mine tuned to 14.5 at idle. I also have an Imagine Auto fuel head that's capable of flowing more fuel. I'm still in the engine break-in period so I'm not pushing things too far. But at spirited runs (some boost), I'm at about 12.3 for AFRs
-jeff
Old 06-26-2006, 01:08 PM
resident samsquamch
sand_man's Avatar
On deceleration, things do go lean
-jeff
Old 06-26-2006, 01:09 PM
What's most important is the AFR under boost. Look for 12.5 or richer. Elsewhere it's more about driveability and emissions, so it's more or less your call.
Matt B
'73 911E
Old 06-26-2006, 01:19 PM
Wo ist die Rennstrecke?
DonE's Avatar
On decel, it doesn't matter. In some cases (with EFI), you can shut the injectors off for greater decel - this will send the AFR off the scale.
On idle, my car likes 12.9 or so, and does not foul plugs. Give it what it wants.
Old 06-26-2006, 06:13 PM
beepbeep's Avatar
It shhould go lean on deccel. Actually, it should shut down fueling completly. As CIS is old and crude, this is impossible so it still injects some gasoline into the engine which leads to backfire on deccel.
Nothing to worry about.
Thank you for your time,
Old 06-27-2006, 07:57 AM
