3 restos WIP = psycho
kenikh's Avatar
Brain dyno - trying to decode lobe centers and durations into HP
I was just looking at a post on the Early S Board from a 906 engine owner. His car, running the same ‘69S heads as mine, using 906 cams, returned 210 HP on a dyno at 7800 RPM. My car is a 2 liter S that is being seriously tarted up.
I just bought some cams from camgrinder that met the drivability and rev range characterstics I gave him to work with. I am trying to use the brain dyno to figure out how much power to expect on top of the power band. I am not concerned about anywhere else in the rev range, as these cams are going to make significantly more HP and Torque sub-4000 RPM than 906 cams due to having very fast ramps.
Looking at the 906 cam, it generates significantly less lift than the custom DC44:
906= .463"I/.460"E
DC44= .490"I/.490"E
The 906 runs on a lobe center of 96 vs. the 102 of the DC44.
The 906 runs durations of:
290I/262E @ .040" and
283I/255E @ .050"
The DC44 runs durations of:
264I/254E@ .040" and
258I/248E@ .050"
Since top end HP is essentially a function of how much and how fast you can get air into the motor, I am wondering if anyone with more experience than me has a guess as to how much HP this motor is going to make at 7800 RPM on the DC44 cam, using the 906 info as a baseline. A real dyno run will come at a much later date.
Thanks!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-30-2006, 10:55 AM
kenikh's Avatar
BTW, assume the same CR.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-30-2006, 10:59 AM
Kenik:
Before I'd venture an educated guess, more information is required.
Heads: stock '69S ones?
Stock-type heat exchangers?
Muffler?
'69 MFI?
Twin-ignition?
CR?
Answer all that and I'll offer something based on similar combinations.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-30-2006, 02:41 PM
kenikh's Avatar
Stock HEs for now; eventually going to headers by George
Muffler is stock for now; something VERY special later (assume megaphones, coupled with the above headers)
'69S MFI
Twin plug: 10.3 - 10.5:1
Feel free to email me on the "muffler" if you are curious.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-30-2006, 03:39 PM
George's headers are too short for these motors,......
Megaphones without a crossover kills bottom and mid-range manners. The effects are exacerbated by longer duration cams.
Any other internal mods? Boattailing? Knife-edged crank?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-30-2006, 03:57 PM
kenikh's Avatar
George's headers are too short? I was assuming he could make them to spec. Let's assume a crossover pipe; since the new exhaust is going to custom fabricated, all is possible.
I wasn't planning on boat tailing or knife edging this motor.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-30-2006, 04:01 PM
George makes one length in these 1.5" headers but he does do a custom version for us, exclusively. You can use his standard one, but you give up some mid-range power.
All in all, I'd expect somewhere around 190-195 HP if you have good flowing heads.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-30-2006, 07:59 PM
kenikh's Avatar
Sounds like I will be buying my headers from you then. Thanks for the feedback. It is actually almost exactly what I hoped.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-30-2006, 09:52 PM
Let me get you a copy of the dyno overlay that shows the HP/torqu differences between the short (normal) and long-tube headers on some 2.0 litre race motors that are configured closely to what you are building.
You'll see what I mean,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-30-2006, 10:27 PM
kenikh's Avatar
Sweet! I can't wait!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-30-2006, 10:34 PM
This matter of headers is interetsting, Steve.
I'm assuming you are using 1 1/2 inch pipes?
I wonder whether , with somewhat more rev-oriented cams, eg DE 60's, 1 5/8 with shorter pipes may give a little more in a racer?
Also must decalre an interest!
Kind regards
Old 07-01-2006, 06:48 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
must...subscribe...
Scott Kinder
kindersport @ gmail.com
Old 07-01-2006, 12:35 PM
Kind regards
Hi David:
Yessir,....these smaller engines; 2.0-2.2-2.4, prefer 1.5" pipes.
Larger diameter pipes simply kill the low & mid-range power without a payback on top (above 6.5K) and they generate uneven A/F ratios which can be observed in the AFR plots. The torque curve mirrors the A/F curve so as mixtures vary, so does torque.
IMHO, larger but shorter primaries do not pay dividends.
There is a possibility that some kind of stepped header might work pretty well too, but that would require some detailed and lengthy dyno tests to prove that.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 07-01-2006, 03:02 PM
Great advice, Steve.
I will pm re headers.
Kind regards
Old 07-02-2006, 01:43 AM
