odd question...rear engine tin ?
I recently blasted my engine tin, and I need to know about a couple of the fastenters. When looking at the flywheel side, to the right (below the reference sensors), there are two holes for attaching the tin....I think those two holes utlize a hex bolt (I think they're called pan-hard screws). Is the tin attached with little hex bolts, or is it by the traditional bolt/washer....? Sorry if it seems like an odd question, but I've had a hard time aligning the tin using the traditional bolt/washer....? Thanks...
86' 911 Carerra
Old 07-11-2006, 09:15 AM
abit off center
cgarr's Avatar
As I remember there were 2 allen head screws somewhere in that area? or as the katalog calls them (pan-head screws)
______________________
Craig
G2Performance
Old 07-11-2006, 09:42 AM
You talkin' to me?
chancecasey's Avatar
yeah the 3.6 has the allen head screws - presumably because there isn't enough clearance to put the standard hex-head bolts in.
-Chance
'90 C2 Cab - Temporarily out of service
Old 07-11-2006, 09:48 AM
That is was I thought as well...thanks for the responses...I'll try it again this evening.
86' 911 Carerra
Old 07-11-2006, 10:13 AM
