911 tweaks's Avatar
What kind of HP does this set up make??
Does anyone have the engine set up in Wayne's book pg 113 as described as follows:
High Performance 3.0L: Remove cis injectiom & replace with
carbs - replace cis pistons with high compression JE
pistons - use early S cams - ssi with sport exhaust.
If anyone has this set up, what are the specifics you are running and how is the "vital" THROTTLE RESPONSE you have?High Performance 3.0L:
I live for 911 tweaks...
Old 07-16-2006, 05:56 PM
911 tweaks's Avatar
any thoughts on running tbitz f/i vs. running carbs? **key engine parameters: throttle response, 91 pump gas, single plug**
Old 07-16-2006, 08:58 PM
3 restos WIP = psycho
kenikh's Avatar
About 240HP, from cross multiplying 160HP @ 2 liters (carbed S cam motor) to 3 liters.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-16-2006, 10:29 PM
911 tweaks's Avatar
Wayne,
Can you share with us the details of your engine? You say "just about". What does this mean?
What internals did you do?
Is this HP at the flywheel or at the wheels?
What is your gas mileage - min octane required - throttle response?
Anything you should of done that would of helped performance?
Running webers or PMO? What size, jetting...?
Thanks alot!! This maybe the engine to fit my resto...and to buy more parts from Pelican!
Old 07-17-2006, 04:49 AM
Super Moderator
cstreit's Avatar
240-250Hp is about right. I had a similar configuration in the racecar with ported heads and a compression bump making about 260...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-17-2006, 07:23 PM
What about TBitz vs Carbs for throttle response??
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 07-20-2006, 03:34 AM
