What kind of HP does this set up make??
Does anyone have the engine set up in Wayne's book pg 113 as described as follows:
High Performance 3.0L: Remove cis injectiom & replace with carbs - replace cis pistons with high compression JE pistons - use early S cams - ssi with sport exhaust. If anyone has this set up, what are the specifics you are running and how is the "vital" THROTTLE RESPONSE you have?High Performance 3.0L:
I live for 911 tweaks... |
any thoughts on running tbitz f/i vs. running carbs? **key engine parameters: throttle response, 91 pump gas, single plug**
3 restos WIP = psycho
About 240HP, from cross multiplying 160HP @ 2 liters (carbed S cam motor) to 3 liters.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Author of "101 Projects"
I have this engine (just about) in my 911 RS clone, and it is very fast. I estimate about 250 HP give or take...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne,
Can you share with us the details of your engine? You say "just about". What does this mean? What internals did you do? Is this HP at the flywheel or at the wheels? What is your gas mileage - min octane required - throttle response? Anything you should of done that would of helped performance? Running webers or PMO? What size, jetting...? Thanks alot!! This maybe the engine to fit my resto...and to buy more parts from Pelican!
Super Moderator
240-250Hp is about right. I had a similar configuration in the racecar with ported heads and a compression bump making about 260...
What about TBitz vs Carbs for throttle response??
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
