Dizzy Differences
I'm wondering about the distributors on the early cars. I've got a 2.4 1973.5 911 with Webers. Everything about the engine is stock except for the Webers.
Is there anything to be gained by swapping to a 911S distributor?
Is there anything to gained by have my current distributor recurved?
Richard Newton
Old 07-31-2006, 11:58 AM
I believe that there is now difference between the advance curve of the 3 engines for the 2.4s. Don't know about the CIS cars (yours) but I'd bet it's the same.
If your engine still has the CIS cams and heads then I don't think you can get more out of a recurved dizzy.
-Andy
Old 07-31-2006, 08:37 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Advance curves change based on compression ratio.
The lower the compression the more the advance.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-01-2006, 06:55 PM
