through bolts seals
I'm sure i've read something bout it a few days ago... but can't find the thread...
well : it was told we don't need silicon or something like that to secure through o bolts seals right ?
only a bit of oil
may you confirm, is this area really a (probably) leaking area ?
thanks
Philippe
Old 07-03-2006, 05:25 AM
resident samsquamch
sand_man's Avatar
No need for the silcone...I used the green o-rings lubed with Dow Corning 111. Be careful not to cut the seals (o-rings) as you install them over the threads of the through-bolts.
-jeff
Old 07-03-2006, 06:42 AM
Irrationally exuberant
ChrisBennet's Avatar
+1
Here's why I don't use the blue O-rings that come with the Reinz
gasket kits:
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-03-2006, 07:02 AM
kirkf's Avatar
I used:
Green Viton O-rings, Lubed with Dow Corning 111 and a sharpie cap to slip them over the bolt threads.
Kirk
1989 911 Carrera 4 (964)
Old 07-03-2006, 06:47 PM
thanks, any loctite reference for a similar product as "dow corning", not available here in france.....?
Old 07-04-2006, 02:16 PM
The "Dow Corning" is just a silicon paste. It's a non hardening grease that lubricates o-rings. You should be able to find a substitute. I found some at a SCUBA shop. They used it on dive watches and regulators. Failing this oil will do.
-Andy
Old 07-04-2006, 02:23 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Green Viton seals on all case through bolts.
We use Dow 55 o-ring lubricant and it is important that the sealing surface is flat. It is not uncommon to see the sealing surface uneven (2.7 mag cases are notorious).
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-04-2006, 04:12 PM
Alan.UK's Avatar
Hi,
I wanted to order some of these Viton seals, but can anyone quickly confirm what size they are?
Alan
Always learning
Old 07-31-2006, 12:29 AM
