ok, dumb question. on-engine thermostat.
is there a correct orientation on re-installing that thing? i didnt note any difference when i yanked it out to change the o-ring. i made the assumtion that the slots in the tstat needed to sit at the correct "elevation" as the two hole in the block? am i wrong?
poof! gone |
The flange w/mounting holes is not symmetrical - you can't install but only one way.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
