up-fixing der car(ma)
Just arrived from EBS! Should be about 10.8:1... I'll start a new thread on this engine soon!!
Scott Kinder kindersport @ gmail.com Last edited by YTNUKLR; 10-13-2006 at 06:05 PM.. |
120 HP/Liter is all I ask
Anyone been using the latest GT3 oil pump in their engines? This is the pump with 2 scavenge pumps.
Try not, Do or Do not
We have used a few and they make huge oil pressure.
In fact maybe too much pressure for some applications. The two stage scavenge is a nice benefit. Scott: One thought on the piston. If you radius the sharp edges on the material between the two valve pockets you will find free horse power. We have found in excess of 5-7 hp by paying attention to this simple detail. This is a real performance upgrade, unlike the boat tail myth.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Interesting on the piston modification, must improve the crossflow beteween intake and exhaust during valve overlap.
Curious, do you mean the pump makes more pressure than the pressure relief valve can control? I like the large scavenge pump and want to use with a breather one way valve from a GT3 to try to develop negative crankcase pressure. I wonder if this will create leaks at the early small diameter crankshaft flywheel seal like it did in the GT3
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche |
I think the GT-3 oil pumps can put the engine-mounted oil cooler at risk but if thats replaced with the oil filter console (993), you'll not have any problems.
Now,..using the one-way valve from the GT-3 Cup cars might give you some oil leaks,...
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Henry, is that engine an MFI 3.0(SC) with slide valve induction and your twin plug set-up? That thing belongs in a centerfold. What kind of power?
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
I was thinking about another thing: wouldn't a very hi-revving engine get away with using slightly higher C/R than low-revving one as VE (thus cylinder filling) would be less perfect on the top?
With other words, engine running VE of 90% on the top would survive with 10% more compression, to do the best possible of available mixture at high revs? You could wind back the ignition where VE peaks upwards 100% and thus save it from knocking but still pull the most of it onn the top? Just a thought...
Thank you for your time, |
This makes me think the residual negative pressure in the crankcase after shut down sucks the seal away from the crank and oil in the galleries above is allowed to "burp" out in small quantities as the pressures equilbrate themselves. I wonder if the large diameter seal is more susceptable to this, than the early seal only one way to find out is to try it myself if nobody else has. |
I am not certain which engine you are asking about. If you are talking about this engine: RSR 3.0 case (new) Special machine work to use 3.3 heads and SC cylinders shuffle pins 95 mm Cosworth pistons 9.8:1 RSR sprint cams Aasco valve springs and ty retainers Supertec head studs Turbo heads,40 mm intake ports 2.2 S crank (66mm) Carrillo rods 930 oil pump Old stock after market distributor (Dick Evelrude ?) 1 of 3 custom build slide valve w/custom Supertec pump Supertec fuel injector lines Getty Design amber shroud 935 8 pin CDs Taylor plug wires European Racing headers w/sport muffler 8500 RPM red line 300+ horse power on 91 octane fuel.
That's really awesome. I bet it was fun to design that on paper and then just go to town on the build up. You must have a very fulfilling job.
If you don't mind what is the bill for something like that? What does it cost to put MFI on an engine that didn't originally have it like an SC 3.0?
IMHO, that's usually something disclosed via PM/email/phone...not to be a party pOOper....I think I speak for Henry, too, when I say this.....just a kind of "etiquette thing" for the buyer/owner of the engine.
Scott Kinder kindersport @ gmail.com |
extra scavenge stage
After doing inventory last night I 'remembered' that I have a GT3 oil pump in box for the 2.8 or 2.1LS build.
So what is the best bet for that center scavange stage? Is it as simple as rotating that section of the housing so that the inlet points upwards? I have not found flow figures, but anything to help remove that cotton candy like oil suspension that rotates with the crank would seem to be a good thing. The other thought would be to run a 'Y' of hardline from that section of the pump up to the rear oil drain back tubes to acheive what Grady was refering to w/o using cam driven pumps a al GT3. Thoughts anyone? tadd
1967 912 with centerlocks… 10 years and still in pieces! |
Tadd,
Be sure to disassemble and inspect your new GT3 oil pump. About a year ago a friend found one where the original casting was improper and the subsequent machining left some untouched. It wouldn’t scavenge correctly. Someplace in the past year or so I saw a nice CNC oil pump that could be driven off the ends of the cams (like Sporto & Turbo.) Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Grady:
Thanks for the tip! I'll check it before it gets used. tadd
It's a 914 ...
Scott |
3 restos WIP = psycho
These should give everyone a chubby:
http://www.barnessystems.com/8917.htm http://www.moroso.com/catalog/categorydisplay.asp?CatCode=13939 http://www.titanspeed.com/content/pump/
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
