Try not, Do or Do not
Accurate information is the best way to guaranty success.
Avoiding a potential problem without accurately identifying what really happened is tantamount to impossible. Your story really tells us that excess is generally an error not that 574 is the culprit. 574 is bright orange, even after curing. My experience says that the viscosity of 574 is so high that it is very unlikely that it would wick more than an inch or so. That says that it probably wouldn't run from the case seem all the way to the main oil galley. My guess is that your spray bar was clogged by something other than 574.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 09-17-2006 at 03:49 PM.. |
From my vast experience of tearing down one engine, which had never been rebuilt, the loctite (I assume) was brownish and not orange.
'79 SC |
Less brakes, more gas!
Having just spent lots of elbow grease cleaning my case (3.0 '82) I can definately say it was black/drk brown and hard as hell to get off... It was very similar to a resin and chipped off on the edge of the sealing surfaces. Case had never been split.
Is it possible that the factory ran out one day and used something else? Or that the formula for 574 canged over the 20+ years? Or maybe, after 20 years of oil it finally got stained black? Was 574 even around in '82? Just curious and enjoying this thread very much! -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
I don't have any more info to add, I just want to 2nd, 3rd, 4th that this is a great thread, and the main players are very civil gentlemen involved in an excellent debate that we all stand to learn from.
Thank you all. |
Constitutional Liberal
I don't build my own engine, but knowing all the thought that goes into a proper rebuild is encouraging.
Someone suggested that reasoning why/what causes problems isn't important. That seems naive. How could anyone know all this without years of experience? We are all lucky that Henry has chosen to participate on this forum. Many people offer impressions but he is giving us true knowledge and reason to boot. |
HI the black/dark brown sealant is Curil K2 made by Elring the gasket people, (part No 534.501 ) and still available, you will also find it on heads/cambox's and the bottom of valve springs by over zealous German engine assembler at the factory.
regards mike |
hI,
First, I agree with and support all the postings on this issue by Mr. Schmidt of SUPERTEC. To the disgrundled member with the unexplained, clogged-up piston spray nozzle - just get over it. Sorry about a clogged oil passage and the damage which resulted, but I doubt in the extreme that it was ever caused by any of the loctite anaerobic products. I remember a clogged up spray hole on number six intake rocker some thirty years ago, which I expected was caused by new sealants (back then we were just moving on from aviation permatex to the "new marvel sealants", the RTV products). The clogged orifice (which ruined the rocker arm, and damaged the cam sufficient that I had to take a knife-sharpening stone to it.........times were tighter in those days for me), also was suspected of being caused by the recently introduced RTV products. I had never/ever heard of permatex finding its way into a spray jet, so the new RTV must be the cause of all this disaster. On much closer inspection though, the tiny, offensive, plug of material, resembled a plant product more than any smooth new space-age plastics?? It looked like cellulose in structure as if somehow a plant form had been introduced to the oil system of that specimen. It was a complete mystery to me until I happened to learn form a third party, several years later, that the first owner of the car had actually violated his warrenty on this 1967 model, by installing and using for about a year, an aftermarket gismo which rested its unfounded claim upon the ability to replace the "expensive" and "inefficient" German oil filter, with a new "Common-Sense alternative" to the BIG-OIL RIPP-OFF of the common man..........an earth-filter using what we already have in abundance", which in addition to saving you money will also double the efficiency of your automotive oil filtration performance and greatly extend the engine life of any car. What was it? what was the miricle product - and where can I get one?? It was an empty aluminum canaster which fit up to the stock filter base on the 911 and any number of other cars. How did it filter the oil? Wait, because you may be too young for this. What one did ....to feed the filter...........was unroll just enough paper from a standard, Mark I, Mod 0, roll of toilet paper, so that it just fit the canaster. I do not suggest that toilet paper would have been the cause of the piston spray clog which has taken this thread so far from its original subject, but I do suggest to all of us, that unless you drove it away from the factory yourself, you cannot possibly know what your Porsche has actually been through. My son was a dealer teck...........You would not be happy to know the truth about Porsche Dealership maintenance. Let's not go there. Secondly, on the subject of the 574 sealant, or any of the anaerobec products...........it seems to me (from reading the responses) that, at least one property of these sealants has not been fully explained. Maybe, of course, I don't understand it (not unusual, but please set me straight). Excepting that, I have found that these wonderful sealants (the loctite anaerobics I consider to be excellent by any defination) will stay "as new" for long (years) periods of time after opening the tube. Yes, you may say, of course, for they will only ever begin to set up in the presence of metal (steel is best - Aluminum not so good) and the absence of oxygen. OK, I expect we can all agree with this, but please note there is no mention of pressure. In other words, the general feeling that one can simply spread on a coating of loctite 574 and not worry much about the passage of time.......untol aht parts are joined....is untrue. Underline it............FALSE!! The very second that 574 materal comes in contact with a metal surface we have met ALL requirements for setup, AND THE CLOCK IS RUNNING! The glue is in contact with metal and there is no oxygen present. Reaction starts - no pressure was ever necessary. The 574 will therefore begin to set up, on that surface alone. Note that the tube instructions call for final clamping of the parts within 10 minutes. This is the reason for the time limt. The time allowed is generous compared to some of the other products.........but one does not have a second to spare, whatever the glue. Dally too long, any you will create, with 574, the thick sealant problems which Mr. Schmidt has noted . Dally too long with other sealants and the results will be also poor. From what I have seen, 574 still offers the longest time............oh, but it is not easy......that 10 minutes starts when the first glue contacts the first metal surface. How many guys do you think can really meet the Loctite 574 time limit? 10 Minutes from the first drop on the case until the two cases are tight. One in a hundred perhaps. No wonder Mr. Schmidt has noted high buildup of 574 on cases he has split. The GM Corp. have a product which is getting rave reviews from the VW group, and I personally wonder whether it might work well for us, but it has only five minutes. Honestly, most of us cannot handle ten on a Porsche 911, so, for my money, loctite 574 is the choice product. Not because it is the Porsche recommendation, but because in my experience, it has never failed to provide a leak-free case joint of sufficient duration to far exceed all the other trouble spots (say, front shaft seal, rear shaft seal, power steering cam take-off shaft seal, and etc.). The case joint has never been an oil leak problem on any engine I have rebuilt. Oil leaks on the 911 engine are, in my view, a part of the design. Don't like it? Then go for a Jap car. Otherwise, accept, as I have, that these engines have a lot of exposure (holes) and should be expected to leak oil if allowed to do so. Maintain them, as you would an aircraft engine or a race engine, and you will never see a drop on the floor. Never. But my brothers, whether you use permatex aviation type II, or type III, or RTV, or Loctite 574, or Three Bond motorcycle sealant, or the new GM Aluminum Engine sealant , or whatever appears next year, my advice is the same...Seal to clean surfaces....Expect to do it again, for nothing last forever, and the leaks will rarely be at the case joint.......the valve cover leaks, the shaft exits, both drive and cam, and the upper engine breather leaks will overshower anything likely to be seeping though the engine case seal.................in my experiene. Finally, be glad that you have an object in your life, which you consider to be worth all this effort, ......Then, GRAB IT - AND GO !!! Regards to all, James |
Forced Induction Junkie
Sorry for posting a question-----I misunderstood the purpose of this forum. Didn't realize the forum is for people who are writing their memoirs! I asked the question because if I had made a mistake of using the wrong materials, I want to know about it.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
You talkin' to me?
I say send in the offending chunk to a lab for some testing
I got pretty worried when after the first break-in, I saw about a 8 inch long but very narrow strip/bead of Threebond 1104 come slithering out the case oil drain hole. Obviously I used a little too much, but someone on this thread mentioned case oil going directly to the filter, but is that really the case? No pun intended. I thought it was possible that case sump oil could bypass the filter. Someone tell me it can't and I'll feel much better!
-Chance ------------------------------------------- '90 C2 Cab - Temporarily out of service |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I guess I must be the "disgruntled" member. I didn't know I was disgruntled but now I know. Just for the record I didn't have any of these problems on any engine I've built or car I've bought. The damage was on an engine that I subsequently rebuilt and knew of the damage before I bought it. I, like James thought it was the sealant. Unlike James however I still think it was the sealant.
I'm hoping we can have a difference of opinion without denegrating each other on this forum. -Andy
72 Carrera RS replica, Spec 911 racer |
Gentlemen,
I seem to have inadvertently rattled the cages of at least two members by my recent posting, and I deeply regret having done so. I just now went back and read over the wording of that post and honestly, I feel a little like the Pope must do. What I wrote there was just what came to mind on the general subjects of this interesting thread. It was never my intent to denigrate the efforts of any member on this forum. No, I do not feel that it is unreasonable to conclude that one would be disgruntled at the necessity of pulling an otherwise fine engine apart just to clear a tiny oil orifice, which never should have been clogged in the first instance. I certainly was quite disgruntled when I did the same exercise. Nevertheless, I note that we do have a spell checker feature on this site, and I shall try and remember to use it in future. James |
James, good on you!
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
JW Pate, I've done what you just apologized for, and for me it felt good to say I was wrong. I hope that you derived some satisfaction from it as well. I'm sure the wounded party or parties will forgive you for any percieved transgression, and all will be well.
If this was real world rather than virtual, we could gather for a beer, but unfortunately we're too far apart. Cheers from a distance. |
Why is sealant used on the main webs anyway? I don't recall Porsche recommending this in their manuals. Too much sealant there could definitely cause clogged squirters or spray bars. I have built a few 911 engines and only used sealant on the case perimeter. The last 88 3.2 I built failed at the case perimeter using the Loctite 574. Fortunately it was just a short block sitting on the engine stand when I noticed a drip under the engine! So I switched to an RTV with no problems. I am curious about the Dirko.
Just thought id post my findings here, ive just stripped a 3.2 that was rebuilt with 574 a little over a year ago. It was my first engine rebuild and undoubtedly over did the sealent. When I stripped it las week I found lumps of solid 574 on the mesh of the oil pump and also this in the through bolt hole.
This is definatly locktite 574 and its very solid If this did come lose im sure it could block larger holes than a cam spray bar. My only thought on why it may have solidified is that I filled the engine with oil a few weeks before it actually ran maybe this caused it to soildify rather than been washed away by the oil? Steve
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 Last edited by 1972_911T; 03-03-2007 at 11:02 AM.. |
The factory used a roller to apply the Loctite very sparingly to the case outer perimeter only, not the through-bolt areas. The last 3.6 I took apart showed signs of shuffling at the through-bolt holes so sealer would not work there anyway. Porsche used a silk screen to apply 574 to the 928 and 944 bottom ends.
Life moves pretty fast.
I agree with rs-vic
I took apart my 3.2, it had never been opened since Porsche made it, there is no sign of any sealant near the through-bolt holes.
Twin plugging, you know it makes sense
I just checked my 3.0 and there are no sealant present from the factory. |
Now I get it. We should never do anything that the factory didn't because they always know best?
Dilivar studs? Shuffle pins ? DC Cams ? My engine building would grind to a halt without them. The factory never used case savers so all you purest stay away from that! Please try to remember that when the factory built their engines they were working with new parts and making a specific horse power.Their processes are quite often dictated by cost not effectiveness. We're required to recondition parts and use those parts to make much more horse power. Our goal is more reliabilty and enchanced performance. BTW: in the early 90s at the beginning of the 964 engine runs, Porsche with new parts and factory trained techs produced a 4% leak average on the dyno. That means 4% of their engines leaked before the engine even made it to the car. No, you won't find that stat in print, but people working in the factory can verify this claim. We are constantly enspired to find ways to improve on the original design and that includes assembly procedures. This process (gluing the webs and using multiple glues) was originally shown to me by Bernard Grundl. Bernard was building 934/935s for Vasic Polack back in the day and he has been working for me some 15 years now. Over the years we have improved on the process. The factory only uses one kind of glue to assemble their engines and we use 5. Do you need five? probably not. But I'll match my assembly process with the factory anytime and we back ours with a two year/unlimited mile warranty that even includes leaking. I have rebuilt or overseen 400+ engine rebuilds and with each engine we look for ways to improve our process. I would like to believe that the last engine is better than the one before and the next one will be better the this one. I refuse to stick my head in the sand and stagnate the process. If you do a servey of the top flight professional engine builders (Steve, Ralph, MB and more) on this forum, I would bet all of them use a process that varies from the factory. Glue or don't, it is ultimately the builders call. In my shop it's my call. Good luck with your project.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 03-07-2007 at 09:26 AM.. |
