Stripped thread on 3.0 air injector
Hi,
Hit a bit of an issue yesterday. After putting the car on the dyno for the first time I had a flat out session up a hill on the way home. Just before the top I blew one of the plugs blocking off the air injector. It looks like the thread is stripped.
Does anyone know what thread diameter is used on the 3.0 79 SC heads. I will see if it can be repaired with a helicoil and some jbweld.
Mark....
Old 09-18-2006, 08:19 PM
Irrationally exuberant
ChrisBennet's Avatar
M10x1.0
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-19-2006, 04:35 AM
Super Moderator
cstreit's Avatar
Are you sure JBWeld will handle the heat though?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-19-2006, 06:05 AM
sww914's Avatar
I've had an exhaust stud JB welded in for 2-3 years. The hole was stripped out except for the 2 top threads, and I didn't have time to fix it properly before a race, so I JB'd it in and hoped for the best. All is well.
Old 09-19-2006, 08:33 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Just go to the hardware store and buy a 1/8 - 27 pipe plug.
It will thread into the existing hole and should stay indefinitely.
If you are nervous about it falling out use red or green Loctite.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-19-2006, 10:13 AM
Thanks guys.... I will go to the local specialty fasterners store for the pipe plug.
Is this self tapping? or do I need to run a tap into the hole? Si there a metric equivalent?
Mark....
Old 09-19-2006, 09:23 PM
In this application (stripped threads) you will find that these plugs will thread in beyond your stripped threads to engage the threads deeper in the hole.
Even though the pipe plug (tapered threads) is not metric the threads are amazingly close. This is not a plug to use of you intend to reinstall air injection in the future.
Henry Schmidt
Ph: 760-728-3062
Old 09-20-2006, 05:30 AM
Henry, can you confirm the size 1/8 -27. Do you mean 3/8 with a pitch of 27?
I did not think of driving the grub screw further into the hole. Thanks for the advice. If we drive further into the hole why not use the M10x1.0 grub screw?
Mark......
Old 09-20-2006, 06:27 AM
1/8- 27 pipe plug.
This is a tapered plug that will lock itself in place. If you use a 10x1.0 plug what would stop it from going all the way through?
We use these plugs all the time without issue.
Henry Schmidt
Ph: 760-728-3062
Old 09-20-2006, 06:57 AM
Thanks Henry - will get one tomorrow.
I have just rebuilt the engine and put in on the Dyno for the first time. I know that Dyno's are all different but I only managed 200rwhp. engine is
3.0 79 sc
10.5:1 JE's
GE80
EBS springs
ITB's
EMS Stinger ECU
Twin plug
Ported heads
SSI
Monty
I though that it would be a but more potent! The torque is good and we have limited it to 7300rpm. What do you think of the results.
Mark....
Old 09-20-2006, 07:04 AM
Super Moderator
cstreit's Avatar
200 RWHP (235 crank) sounds a little low... but not outrageously so. I would have guessed closer to 250 crank HP. Can you post your dyno sheet? How's your air/fuel?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 09-20-2006, 07:15 AM
211 DIN RWHP and 268 Ft /lbs of torque
10.5:1 JE pistons
40 mm ports
DC 60 cams
Shuffle pins
Knife edge
46 mm PMO
1 1/2 " headers
Henry Schmidt
Ph: 760-728-3062
Old 09-20-2006, 08:44 AM
Loose nut bhind the wheel
Another nice motor Henry. Does the drivers side air duct behind the distributor need to be modified for clearance? If so can you post a picture? I am not to the point where I can test fit mine.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 09-21-2006, 08:40 AM
Thanks Henry......took awhile down at the shop. The young guy had no idea the old fella went straight to the box and gave me the grub screw.
Retapped the whole thread locked and screwed.....sounds dirty!
All is good.
Chris I will put it back on the Dyno in a few weeks after I replace the TPS sensor and post the Dyno sheet in a new thread. The more feedback the better.
Nice motor Henry........make my backyard rebuild look like a ..........well a backyard rebuild!
Cheers
Mark......
Old 09-25-2006, 05:47 AM
The tin is from a 930 Turbo.
It is possible to modify a stock piece from an early 911.
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2006, 06:04 AM
PJMARKOW's Avatar
Hi Mark,
Sounds like your getting that engine running OK. Is it run in yet? You could be down a little if the rings etc haven't seated yet. Did you use the dyno at Autotech? My car registered 230Kw at the rear wheels on that dyno (3 litre turbo, K27, Kolkeln, headers, 7.5:1 JEs, .8 bar), but I'am sure it's getting more now that it's completely run in.
Cheers
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 09-25-2006, 03:07 PM
Hey Paul,
Yes almost there......did quite a bit of road tuning and then went to see Peter.......Changed quite a bit. Also found a TPS issue which made tuning hard. I will replace the TPS, once we identify what it is! and try again.
Have been driving the car all week, goes OK but I expected more.
Your car is really driving the horses........!
Wil give you an update soon.
Mark.....
Old 09-26-2006, 05:59 PM
