Your input on 3.0L engine with 3.2L Ps/Cs please
Hi everyone,
I am thinking about putting together a 3.0L engine with 3.2L Mahle Ps/Cs (for street and occasional DEs in a 1972 chassis) and hoping that you can give me some input on what to pay special attention?. Here is what I have so far: - 3.0L case with std. 70.4mm crank, - set of 78SC heads or a set of SC ported, twin-plugged heads I am looking to buy from Scott Kinder (YTNUKLR), - set of Sc grind (will be 964 grind) cams - CIS set up - Set of 3.2L Mahle Ps/Cs for CIS -SC single plug ingnition What else am I missing?. I will have the SC rods machined to use with the 3.2L Ps/Cs and get a set of 23mm wristpins. Future direction for the same engine, -Higher compression JE pistons -More aggressive cams -40mm IDA Webers -964 distributor Thanks you all in advance for your inputs. Andy |
I am confused about your description of the P/C set. Are they 98mm for use with a 22mm pin (SC rod) or are they 95mm pistons from a 3.2 that have 23mm pins?
If they are 95mm from a 3.2, save your money. They have the wrong pin diameter and they are designed for a shorter rod and you will still have 3.0 displacement as the 3.0 uses a 95mm bore as well. Could you clarify? Thanks
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Yes, still 3.0 L..
But the 3.2 piston is a much better piece allround than the 3.0..and offset drilling the pin bore in the rods makes up for the loss of compression height. Kind regards david |
Hi David, Have you completed your 3.0L engine using the 3.2L Ps/Cs yet?, or did you go with something else?. Andy |
up-fixing der car(ma)
Andy, as shown by Herr Schmidt II (Henry), the 3.2 P/C can work well on the 3.0L base. I think the heads that I have for you will work very well on this config., and I'm not just saying that so you buy them
. Obviously you can stick a dummy plug in there and run it as a single-plug motor, and upgrade when you want to, down the road. Another great combo (that you may decide if/when you install JE pistons) is changing the cylinders to 98mm, either with Nickies, QSC or bore your 95mm Mahles and replate, etc. That will give you 3.2L but with a different borexstroke (98 x 70.4)from Porsche's original 3.2 (74.4 x 95mm). I have a 3.2L (stock) engine on my stand right now. Originally, I ordered 964 cams for this motor from Camgrinder (on the forum). Now, it looks like we're going with something different--perhaps a modified DC20 or maybe even something a lot hotter if this guy decides he wants carbs and JE pistons instead. So, I have a set of brand-new 964 cams for sale, if you're interested. I'm sending you another PM. Best regards, Scott
Scott Kinder kindersport @ gmail.com |
Thanks Scott. I already have a set of 3-bearings SC cams and I won't know what to do with it if I buy your cams. So, I'll send it out to have it regrind. What would be a good cam for this engine if I were to run the 40mm Weber on it?, with CIS pistons?. BTW, I just send the payment for the heads via paypal. Thanks. Andy
Thanks Andy. A good cam for CIS piston/Weber 40s is the 964 or even the 3.8 Supercup from John D. @ drcamshafts.com.
Cheers
