zbph10's Avatar
Which valve guides should I buy?
Pelican sells a couple of different valve guides and I'm curious if it makes difference. Bronze and Phosphorus bronze.
Also curious what the oversized ones are for?
Figured since the motor is apart and the valves seem to have a very slight wobble to them I'd replace them all.
Brian
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 09-27-2006, 08:41 PM
3.4 Bigger is better
88-diamondblue's Avatar
Were the heads done when the other engine work was done? I would consider sending the heads out to get the work done, I would not trust anyone who hasn't done them before. And I believe that Manganese bronze are what were put in the heads.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 09-27-2006, 09:01 PM
Brian,
These are the heads after they came back from Supertec.
Michael
2020 Honda Passport
Old 09-27-2006, 09:13 PM
zbph10's Avatar
Whats' the cost of having this done?
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
Old 09-28-2006, 06:31 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Manganese bronze offers much better wear characteristics and the phosphorous bronze offers superior cooling.
In turbo and race heads (anything making high exhaust temperatures) we use the PB guides for the exhaust valve.
On most street engines we use MB exclusively.
BTW: the exhaust valves guides generally get a slightly larger clearance to allow for better oiling. High performance turbos generally run without valve stem seal . This promotes cooling and reduces wear.
Yes oil consumption can go up.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-28-2006, 07:58 AM
WydRyd's Avatar
Interesting. Protomotive recommended AliSiBr valve guides for my blown Carrera motor. They said they are very durable and are excellent for high power turbo motors
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 10-05-2006, 10:20 PM
