iamchappy's Avatar
Header Heat Exchanger size for 3.1 turbo
What do you forum experts think would work best for heat exchangers to use on my 3.1 turbo engined 914-6 during the cold months that I am still able to drive. Would the stock diameter 914-6 exchangers work ok or would the diameter of the tubing be to small, or with a turbo does it even matter.
What size performance pipes do the 930's and C2's run : 1 1/2 ,1 5/8's or 1 3/4's ?
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 10-05-2006, 07:48 PM
1 5/8" is very nice.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-05-2006, 07:58 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I know of no benefit to running a large headers on a small displacement turbo engine. A larger header may even cause a slower spool up. 934 factory headers were only 1 1/2 inches and they made 540 hp with cis.
There is some benefit in controlling the heat that escapes through the headers. You may find some reasonable gain by wrapping the headers to hold in the heat..
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-05-2006, 08:32 PM
iamchappy's Avatar
Any heat escaping the headers I would like to direct to the cabin when it's 20º outside and theres frost on the windows.
Henry do you think the stock 914 6 heat exchangers that were designed for a 2 liter would work well for me then?
87 924S
Lexus SC400
Lexus LS400
Old 10-05-2006, 08:45 PM
I absolutely believe that 1 1/2 inch headers will work magic in your application.
Measure the od of the headers and you'll know what size they are. My guess: 1 1/2 inches.
Henry Schmidt
Ph: 760-728-3062
Old 10-05-2006, 08:55 PM
iamchappy's Avatar
Thanks as always Henry!
87 924S
Lexus SC400
Lexus LS400
Old 10-05-2006, 09:03 PM
