carrera 3.0 heads versus 81 sc heads
I have a chance at some carrera 3.0 euro heads and was wondering if there is any benifit to my application of my 3.0 that is turbocharged?? Is the head stud spacing the same?? Thanks
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-11-2006, 05:34 AM
Bill Verburg's Avatar
930/02 C3 heads are the same as 930/03 RoW '78-79 SC, 930/04 US '78-79 SC, 930/05 Jpn. '78-79 SC, 930/06 Ca. '78-79 SC
In '80 SC Intake ports were reduced in size to speed intake air velocity
930/50 RoW '75-77 turbo used even smaller intake ports but bigger exhaust ports
930/60 RoW '78-79 turbo used the small intake ports and smaller exhaust ports
Bill Verburg
Old 10-11-2006, 08:47 AM
so from what porsche did the smaller the intake port that I currently have may be a benefit?????
Ben
89 944,85.5 944
914-6werkshop.com
Old 10-11-2006, 08:52 AM
Smaller ports will speed up gas flow, this has a tendancy to give better throttle response, it may have an effect on emissions and probably fual milage as well.
My only experience w/ different port sizes comes from racing motorcycles, we had small port heads for shorter , tighter circuits and big port heads for longer faster circuits. Pipes and tuning were also changed of course.
Bill Verburg
Old 10-11-2006, 09:10 AM
abit off center
cgarr's Avatar
I know on a carbureted engine its important or helps to taper the ports/intake towards the head to keep the speed of the fuel/air mix suspended and to help charge the cylinder when the valve opens but on a turbo or injected motor I don’t know if it would really matter that much since you can really increase the charge by increasing the boost? I don’t know I am just thinking out loud..
______________________
Craig
G2Performance
Old 10-11-2006, 09:44 AM
Super Moderator
cstreit's Avatar
No wonder it was so quiet.
I'm going to speculate with Craig... I but it seems that the factory did the opposite... Could this have something to do with the CIS of the time though?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-11-2006, 12:26 PM
Yes the smaller ports should be better for you because your engine is turbocharged. This would be closer to the turbo heads (32mm I believe). I hope you are putting lower compression pistons in.
-Andy
Old 10-11-2006, 09:39 PM
looking at some nice JE 8.0-1 for turbo application pistons from henry.. As I read more I see the spectrum OF CR for turbo cars was as low as 6.5-1 and as high as 10-1 so What had was not out of control but did not like to over boost
Ben
89 944,85.5 944
914-6werkshop.com
Old 10-12-2006, 04:00 AM
