}{arlequin's Avatar
help w/ early turbo case
this smooth compound that's to the left of the slotted screw... it's some kind of a patch. can anyone tell me what type of damage this could be hiding? there is no visible crack from the inside. does this mean the condition of this case is "terminal"? thanks.
dave
1973,5
Old 10-13-2006, 06:10 AM
Super Moderator
cstreit's Avatar
Sure looks like JBWeld.... Probably cracked or hit that side of the case. I guess the things I'd worry about it are:
1. Flow obstruction. You don't know how big the crack or hole is and therefore how much of the patch got pushed into the oil channel.
2. Will it break again?
If it were my engine I'd probably want to remove that crap and have a good aluminum welder make a more permanent repair. This certainly reduced the value of the case, but I doubt it's rendered unusable.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-13-2006, 06:45 AM
Dave, I'd say it's junk and you should sell it to me cheap!
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 10-13-2006, 02:36 PM
send it to me I'll fix it along with jerry's/chris's 3.0 case
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-13-2006, 04:26 PM
Try not, Do or Do not
Henry Schmidt's Avatar
There is a steel tube cast into the case under the aluminum at that point. A porous casting in this generally area are not uncommon and the factory recommended this type of repair. However it looks excessive. I would remove the adhesive (a propane torch will make it easy) access the damage and repair it if possible.
Without removing the adhesive there is no way to determine if it's repairable or not. My guess is that it will be repairable.
Good luck.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-13-2006, 11:27 PM
