Do I need to install tensioners during dry assembly?
as above, finished cam timing and ready to move to piston-valve clearance check. I have mechanical chain tensioners in place from cam timing and I can't see much utility in priming and installing the pressure fed tensioners for the piston-valve clearnace check...they are just gonna have to come back out in a few hours. Am I missing something that would require me to install at this time or can I just leave the mechanicals in place till I tear back down for sealing?
Richard Lane 1978 911SC 1973 "Clean" RS clone |
Air Medal or two
logic dictates tension is tension so ...how could it mater ??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Thread Tools | |
Rate This Thread | |
