CBRacerX's Avatar
964/993 Plug Wire End Orientation...
Ok, I goofed. When I installed new Beru plug wires on my 964 wiring harness, I did not notice that the plug ends come in two varieties, with a positive or negative exit angle of the wire. Duh! I think there are 4 that have a negative angle, with the remainer positive. But where do they belong?
Thanks!!!!!!!
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 12-03-2006, 03:11 PM
Re: 964/993 Plug Wire End Orientation...
Are you talking about the actual wire or the connector? If the connector than #3 exhaust is different (on the right in the photo below) but if you mean the wire ends than I think #1, #2, #5 and #6 exhaust are different or I'm not sure what you're asking?
Old 12-03-2006, 05:24 PM
CBRacerX's Avatar
The wire ends are my interest. In your picture, the angle of the wire connection is the same for both connectors. In my collection of wire ends, 4 of them have a different angle that what you have pictured.
Chris
Old 12-03-2006, 06:04 PM
Based on what's written in PET I'd go with the connectors for cylinders #1, #2, #5 and #6 all on the exhaust side as being different on your engine.
Old 12-03-2006, 06:12 PM
CBRacerX's Avatar
Thanks! I'll take that advise and try it out.
Chris
Old 12-03-2006, 06:19 PM
CBRacerX's Avatar
Well it turns out that 1,2,3 Exhaust and #1 Intake are the homes of the different connectors, at least that is what my install showed...
Chris
Old 12-04-2006, 10:39 AM
