-   -   my 3.2 ss/twin plug/turbo motor (http://forums.pelicanparts.com/911-engine-rebuilding-forum/323599-my-3-2-ss-twin-plug-turbo-motor.html)
Mysterytrain 01-17-2007 06:13 AM
Ben,
The fan looks nice. What did you do to the center hub..is that cad paint?
mb911 01-17-2007 06:06 PM
the trick was hest to heat up the steel with a propane not enough to screw up the powdercoating but enough to void it of moisture and warm to the touch then sprayed some gold spraypaint it boils a bit then I cleared it 3-5 minutes later with satin clear.. I have tried this many times before and works well..
mb911 01-22-2007 04:53 PM
as you can tell time is limited but here is as of last night
http://forums.pelicanparts.com/uploa...1169513597.jpg http://forums.pelicanparts.com/uploa...1169513624.jpg
jcc911 01-22-2007 05:10 PM
Where is the GSF crank pulley? :-)
mb911 01-22-2007 05:42 PM
sitting on the bench.. It does not have holes in it for my specail crank pulley tool so I just used this for timing and valve adjustment
Lukesportsman 01-22-2007 06:11 PM
Did you have these professionally powder coated or is this a Eastwood kit?
Facey 01-22-2007 10:52 PM
no cf engine shroud bling?
-i find it impossible to clean up the stock piece, i've sanded, painted, re-painted....its not good.....
i've never seen powder coating that light blue/grey before, but i think i like it.
whats your hp goal on this beast? should rev nice being such a short stroke.
mb911 01-23-2007 10:16 AM
It is machine gray and I sent it to euroeast and they did there (powder coating)
The shroud was painted then I stripped it back off and I buffed and it turned out pretty well It still has compound on it but it is fairly glossy. I though about replacing it but really it will be covered by the 3.2 intake and the IC so No one will see it..
Hp is 300-350 As I want it to last for a while
Facey 01-23-2007 10:23 AM
sorry, crank or wheel?
either way should be dependable.
exciting, have you test fit the IC yet? or is that to come?
what is your combustion chamber volume?
mb911 01-23-2007 05:40 PM
heads are 92cc Did not cc the domes but they are very close to flat top JE's that henry@supertec said were 8- 8.5-1 depending on head so I am very comfortable with that I would like to 300 at the wheels.. I of course need to change some things but easily atainable if I want.. The IC and turbo mount up with be showing up very shortly in the pics
Lukesportsman 01-23-2007 07:38 PM
Was it Motodelta or Euroeast who did the powdercoating? Who did you contact for this service because I couldn't determine this from their website? You can PM details if you don't wish to waste band width here. Look'n good.
jcc911 01-23-2007 07:43 PM
Euroeast
mb911 01-26-2007 05:30 AM
ok here are some pics as of this morning 5 am.. The piston is of why we started this fun adventure as you can see it is still usefulhttp://forums.pelicanparts.com/uploa...1169818158.jpg http://forums.pelicanparts.com/uploa...1169818174.jpg http://forums.pelicanparts.com/uploa...1169818196.jpg http://forums.pelicanparts.com/uploa...1169818213.jpg
tony77targa 01-26-2007 09:06 AM
Ben.... looks awsum!!! are you going to be running crankfire with your MS ...
mb911 01-26-2007 09:16 AM
thats the plan but I will get it up and running again with the dizzy first
hobieboy 01-26-2007 01:29 PM
Ben,
Trying with dizzy first is great idea, but should also hook up the VR sensor & pulley before you put the engine back in.
It will be easier (no need to change pulley with engine in car) and you can probably test the circuit prior to going all the way :)
Porsche_monkey 01-26-2007 01:35 PM
I don't like it. I really don't like it. The walls should be drywall, not particle board in your garage.
But that engine will be sweet.
mb911 01-26-2007 06:24 PM
Originally posted by hobieboy
Ben,
yeah thats the plan just used this pulley to turn the engine over for valve adjustment
OH AND I HATE DRY WALL thats why i went osb
935TURBO 01-27-2007 09:48 AM
Hi Ben,
really nice work...!.....about painting parts....don't you think that the powdercoated will stop a little bit heat exchange....?
mb911 01-27-2007 10:13 AM
Originally posted by 935TURBO
Hi Ben,
yes it will but how much reallY?? porsche use to powder coat the upper valve covers .. The chain cases should not be to much of a problem either lots of guys have done this in the past..
