-   -   my 3.2 ss/twin plug/turbo motor (http://forums.pelicanparts.com/911-engine-rebuilding-forum/323599-my-3-2-ss-twin-plug-turbo-motor.html)
mb911 01-07-2007 09:55 AM
as I said many folks showed interest so here is a bunch of pics etc.. http://forums.pelicanparts.com/uploa...1168195843.jpg http://forums.pelicanparts.com/uploa...1168195862.jpg http://forums.pelicanparts.com/uploa...1168195896.jpg http://forums.pelicanparts.com/uploa...1168195920.jpg http://forums.pelicanparts.com/uploa...1168195942.jpg
I will take more as I progress. But here is whats in it
rods rebuilt=supertec
oil pump modded to flow 30% more=supertec
qsc 98mm cylinder=supertec
JE turbo pistons=supertec
twin plug heads=garret bros racing
And much more to come .. I will so everything thing that goes into it with the turbo fab and install again.. and I am the bozo in the blue
jbrinkley 01-07-2007 10:26 AM
it'll be a fun summer
http://www.pelicanparts.com/support/smileys/pray.gif
Facey 01-07-2007 10:26 AM
that sounds like a build for power if you ask me.
wicked.
jcc911 01-07-2007 10:57 AM
Engine Build
Looks Awesome! Keep us updated with the rest of the build... work well done by a master engine builder;) (sorry I had too.)
Can't wait to see and hear the finished piece of art.
Not to mention, Very Envious Too, Good Luck with the rest of the project!
KCPSG 01-07-2007 11:35 AM
Looks great,
http://www.pelicanparts.com/support/.../hotbounce.gif
jbrinkley 01-07-2007 12:16 PM
MASTER ENGINE BUILDER......... lol
mb911 01-07-2007 07:00 PM
more progress todayhttp://forums.pelicanparts.com/uploa...1168228768.jpg http://forums.pelicanparts.com/uploa...1168228791.jpg http://forums.pelicanparts.com/uploa...1168228814.jpg http://forums.pelicanparts.com/uploa...1168228836.jpg
quattrorunner 01-07-2007 07:19 PM
sub, why not
tony77targa 01-08-2007 05:42 AM
Hey Ben... that looks awesum! one ? are you running dilavar studs top and bottom ? and if so why?
mb911 01-08-2007 05:55 AM
no they epoxy coated steel studs. they use to be sold as dilivar but I verified they are steel.. I believe they also were marketed as "super-studs" which is just a stock steel stud..
quattro not sure what that means?????????:confused:
sus911 01-08-2007 10:36 AM
looks like it'll be the goods Ben.
Who you gonna get to knock you up an exhaust??
Phil
quattrorunner 01-08-2007 11:59 AM
It means I am subbed to a few other threads and why not this one too? No offense, I should not have includes the "why not" part.
quattrorunner 01-08-2007 12:00 PM
Nice choices with your build so far.
Lukesportsman 01-08-2007 03:14 PM
What's prettier, the twin plugs or your mug?
Nice! So much for our plans all those months ago when we were both talking about cheap/budget turbo builds. You've certainly fell off that slippery slope now.
Ignition duties? MSII or 12 plug dizzy? You may have mentioned and I may have forgot.
My exhaust housing should be there by tomorrow.
mb911 01-08-2007 05:11 PM
MS I If I can get that all figured out... I got some good people helping me out
cstreit 01-08-2007 09:07 PM
Looks good Ben, can't wait to hear it run!
mb911 01-11-2007 11:19 AM
a little gruppeb bling here.. new powdercoated parts.. soon to be installed.. Sorry not much progress I did not have enough chain ramps so had to order them in.. maybe we will be completed this weekendhttp://forums.pelicanparts.com/uploa...1168546714.jpg http://forums.pelicanparts.com/uploa...1168546742.jpg
WydRyd 01-11-2007 08:31 PM
Whoo hoo! Another HP Junky in the making! Very nice :D
Mike Andrew 01-15-2007 03:10 AM
Geez, Ben,
That is looking really sweet. Any ideas on HP when you have finished?
mb911 01-15-2007 03:48 PM
Originally posted by Mike Andrew
Geez, Ben,
I am just shooting for the same 300-350 or so hp.. just building it for longevity though it will be capable of allot more..
Mysterytrain 01-17-2007 05:13 AM
Ben,
The fan looks nice. What did you do to the center hub..is that cad paint?
mb911 01-17-2007 05:06 PM
the trick was hest to heat up the steel with a propane not enough to screw up the powdercoating but enough to void it of moisture and warm to the touch then sprayed some gold spraypaint it boils a bit then I cleared it 3-5 minutes later with satin clear.. I have tried this many times before and works well..
mb911 01-22-2007 03:53 PM
as you can tell time is limited but here is as of last night
http://forums.pelicanparts.com/uploa...1169513597.jpg http://forums.pelicanparts.com/uploa...1169513624.jpg
jcc911 01-22-2007 04:10 PM
Where is the GSF crank pulley? :-)
mb911 01-22-2007 04:42 PM
sitting on the bench.. It does not have holes in it for my specail crank pulley tool so I just used this for timing and valve adjustment
Lukesportsman 01-22-2007 05:11 PM
Did you have these professionally powder coated or is this a Eastwood kit?
Facey 01-22-2007 09:52 PM
no cf engine shroud bling?
-i find it impossible to clean up the stock piece, i've sanded, painted, re-painted....its not good.....
i've never seen powder coating that light blue/grey before, but i think i like it.
whats your hp goal on this beast? should rev nice being such a short stroke.
mb911 01-23-2007 09:16 AM
It is machine gray and I sent it to euroeast and they did there (powder coating)
The shroud was painted then I stripped it back off and I buffed and it turned out pretty well It still has compound on it but it is fairly glossy. I though about replacing it but really it will be covered by the 3.2 intake and the IC so No one will see it..
Hp is 300-350 As I want it to last for a while
Facey 01-23-2007 09:23 AM
sorry, crank or wheel?
either way should be dependable.
exciting, have you test fit the IC yet? or is that to come?
what is your combustion chamber volume?
mb911 01-23-2007 04:40 PM
heads are 92cc Did not cc the domes but they are very close to flat top JE's that henry@supertec said were 8- 8.5-1 depending on head so I am very comfortable with that I would like to 300 at the wheels.. I of course need to change some things but easily atainable if I want.. The IC and turbo mount up with be showing up very shortly in the pics
Lukesportsman 01-23-2007 06:38 PM
Was it Motodelta or Euroeast who did the powdercoating? Who did you contact for this service because I couldn't determine this from their website? You can PM details if you don't wish to waste band width here. Look'n good.
jcc911 01-23-2007 06:43 PM
Euroeast
mb911 01-26-2007 04:30 AM
ok here are some pics as of this morning 5 am.. The piston is of why we started this fun adventure as you can see it is still usefulhttp://forums.pelicanparts.com/uploa...1169818158.jpg http://forums.pelicanparts.com/uploa...1169818174.jpg http://forums.pelicanparts.com/uploa...1169818196.jpg http://forums.pelicanparts.com/uploa...1169818213.jpg
tony77targa 01-26-2007 08:06 AM
Ben.... looks awsum!!! are you going to be running crankfire with your MS ...
mb911 01-26-2007 08:16 AM
thats the plan but I will get it up and running again with the dizzy first
hobieboy 01-26-2007 12:29 PM
Ben,
Trying with dizzy first is great idea, but should also hook up the VR sensor & pulley before you put the engine back in.
It will be easier (no need to change pulley with engine in car) and you can probably test the circuit prior to going all the way :)
Porsche_monkey 01-26-2007 12:35 PM
I don't like it. I really don't like it. The walls should be drywall, not particle board in your garage.
But that engine will be sweet.
mb911 01-26-2007 05:24 PM
Originally posted by hobieboy
Ben,
yeah thats the plan just used this pulley to turn the engine over for valve adjustment
OH AND I HATE DRY WALL thats why i went osb
935TURBO 01-27-2007 08:48 AM
Hi Ben,
really nice work...!.....about painting parts....don't you think that the powdercoated will stop a little bit heat exchange....?
mb911 01-27-2007 09:13 AM
Originally posted by 935TURBO
Hi Ben,
yes it will but how much reallY?? porsche use to powder coat the upper valve covers .. The chain cases should not be to much of a problem either lots of guys have done this in the past..
