just giving and update still running wellSmileWavy
Some day, mine will too, and I am getting closer each day. Hopefully before the first snow flake drops.
Can't wait! |
Ben, how did the dizzy work out for you?
it works great. Infact I need to bring it up to your suggested 10 degrees advance at idle. it is still about 6-7 right now..
Well got 1700 miles on this year Dumped the oil last night the oil was still Pink (amsoil 20w50 racing) No chunks so Very happy with the car .. Next year in spring do a dyno run and tune for a bit more boost while running the new twin plug ignition. Shooting for 350 at the wheels
It's spring now ... any news with the dyno run?
IIRC Jerry got 326 Hp to the rear wheels using Ben's set up. This was in February.
Phil hows yours running |
Still running great...however since buying the GT3 the white car doesn't see nearly as much road time. Once things cool off down here again It'll get driven more.
This car now needs an electronically controlled water fogger to get that boost up even higher! http://forums.pelicanparts.com/911-engine-rebuilding-forum/416128-water-injection-high-compression-naturally-aspirated.html This link is for NA applications, but there is great turbo info. |
Ben...just read the whole thread. That is a b@dass engine. Exactly what I would do, right down to the grey. (Then again, it's apparent I have a thing for grey...)
I'll bet it rips on the street. Nice job, and beautiful exhaust! |
Ben,
How do you like the Amsoil 20W50 racing oil? I've been using it over a year now and I really like it. My engine temps dropped 10 degrees after changing from Castrol to Amsoil, but I also swapped the CIS for Webers, so that accounts for some of the temp drop. |
to be honest I can't really tell but I have always ran mobil 1 or amsoil so it runs about the same |
I like the equal length primary tubes at what should be the right size for the best pre boost torque and much more even heat level at the exhaust ports. For me I would add a split dedicated secondary tubes all the way to a split scroll turbo if not already done. Looks like a best of class set up. If I do another turbo (78 & 91), I will come a calling. Not an expert, just what I like. |
Hi Ben,
Was reading your thread, wow what a big jump from the early days of muffler fab; nice work!! One thing I'm surprised you don't have on the secondary pipes; no expansion bellows. When the headers get red hot, wouldn't you want some expansion provision?? Regards, JP |
I was thinking about doing a twin scroll next with dual wastegates. Not right now as with the economy in a major down turn I just drive it and enjoy but you are spot on. This thing pulls from approx 3000 rpm to redline with no drop off the turbo though is a bit large for the boost levels I run (.5 bar) but with the ssi's I get great off boost performance
Jp I had though about the bellows but I also figured I knew someone whom welds;) so if it cracked I could fix it easily. So far its has worked well. I would have to check but I think I have about 6,000 miles on it and has worked well |
Dual wast gates would make this the near perfect street turbo set up.
I am suspect of the wast-gate circuit design that B&B and others use. I think there are potential issues with them. First I believe they trick the WG into delivering a bit higher level of boost than stock. Not sure if it is the way it connects to the header system or the length of the tube to it. I also suspect that with many of us running small hot sides and larger compressor wheels trying for earlier boost onset and for more efficient top end. The by product being the WG circuit has to flow more than it was originally sized for. This can create boost creep and the big bang if one dose not have an over boost shut off switch. This could be a solid product for you. The Turbo guys are used to spending big dollars to feed there addiction. Keep up the good work. |
I agree but I need to secure 930 here for a 100% stock bolt up situation then do the dual waste gate setup. I may sell the back half of what I have to finance the DWG setup? |
Why did you increase the oil pump by 30%? What did Henry do specifically?
I want to see some ripping videos... it should be fun
it is fun and has been changed a bit since the build with twin plug dizzy,993 heat exchangers with the y I fabbed below and different turbok27Shttp://forums.pelicanparts.com/uploa...1235349766.jpg |
Niiiiiiiice!
your next for this jeff:D
Ben,
I would love to build a turbo motor for my car as well, but it would be a second motor. Ideally I would build a low boost quick spool turbo out of 3.4 or 3.5 with intercooler to fit under a ducktail. Then I would also have a second transmission for it and I would swap them depending on my mood :) Cheers |
here is my mock up. the engine is out right now for some tranny work and I am adjusting valves while its out so no good pictures but here is the mock up. Jeff I can supply you with as many turbo parts as you want that way I will have spare wheel though only 1 car:D http://forums.pelicanparts.com/uploa...1235651809.jpg |
:)Couple of thoughts. Low cost is bore the stock P&C to 3.3 and run J&W's.
Better yet, start with a 3.2 adding a 3.6 crank with factory 3.3 or 3.4 P&C's makes for a great, strong turbo motor. The longer stroke helps pre boost as dose the increased compression it adds. I think you can shoe in a Carrera intake with custom intercooler. An alternative is to convert a 930 pancake intake manifold to EFI and extrude hone it. This would give you a lot of room for the IC. With EFI, the longer stroke, added compression, and the righ turbo you do not need to go low pressure to get drivability. Now you can access 500hp if desired with boost starting under 2000rpm. A 76-77 short bell housing Turbo transmission would be a great match. Might try a built 915 with boost control to keep boost down in first. A G50/50 (C2 turbo) is the cream of the crop and if you change out 2-5th gears from a normal C2 or 4 it will flat rock. Sorry, could not help myself but this is one of my dreams. A monster single turbo in a 74 or 73RS body. |
While we're busy spending Ben's money, why not do a 3.8 L motor and a 6 speed G50?
That's where you'll end up anyways :D:D Doug |
Or maybe it's possible to build a "torquer turbo" with one of those 76.4mm cranks and the larger PCs. Then keep the revs mild and emjoy big torque both on and off boost. |
