I want to see some ripping videos... it should be fun
it is fun and has been changed a bit since the build with twin plug dizzy,993 heat exchangers with the y I fabbed below and different turbok27S
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Niiiiiiiice!
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
your next for this jeff
Ben, you got a picture of this installed?
'87 3.2 with a twist.....371bhp and 325lbs/ft |
Ben,
I would love to build a turbo motor for my car as well, but it would be a second motor. Ideally I would build a low boost quick spool turbo out of 3.4 or 3.5 with intercooler to fit under a ducktail. Then I would also have a second transmission for it and I would swap them depending on my mood ![]() Cheers
here is my mock up. the engine is out right now for some tranny work and I am adjusting valves while its out so no good pictures but here is the mock up. Jeff I can supply you with as many turbo parts as you want that way I will have spare wheel though only 1 car ![]()
Couple of thoughts. Low cost is bore the stock P&C to 3.3 and run J&W's.Better yet, start with a 3.2 adding a 3.6 crank with factory 3.3 or 3.4 P&C's makes for a great, strong turbo motor. The longer stroke helps pre boost as dose the increased compression it adds. I think you can shoe in a Carrera intake with custom intercooler. An alternative is to convert a 930 pancake intake manifold to EFI and extrude hone it. This would give you a lot of room for the IC. With EFI, the longer stroke, added compression, and the righ turbo you do not need to go low pressure to get drivability. Now you can access 500hp if desired with boost starting under 2000rpm. A 76-77 short bell housing Turbo transmission would be a great match. Might try a built 915 with boost control to keep boost down in first. A G50/50 (C2 turbo) is the cream of the crop and if you change out 2-5th gears from a normal C2 or 4 it will flat rock. Sorry, could not help myself but this is one of my dreams. A monster single turbo in a 74 or 73RS body. |
Metal Guru
While we're busy spending Ben's money, why not do a 3.8 L motor and a 6 speed G50?
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
That's where you'll end up anyways ![]() ![]() Doug
1971 RSR - interpretation |
Or maybe it's possible to build a "torquer turbo" with one of those 76.4mm cranks and the larger PCs. Then keep the revs mild and emjoy big torque both on and off boost.
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) |
