Anyone have access to a 964 plastic intake?
Hello all,
Does anyone have access to a 964 plastic intake (preferably removed from the engine)? Please can you take pictures of all angles and include all measurements on it? I would like to fabricate one from stainless steel, improving the documented inefficiencies and adapting it to fit my vehicle.
I do not want to use a plastic intake with adapters.
Many thanks in advance,
F.
1979 Porsche 911 SC
Old 01-10-2007, 10:33 AM
Irrationally exuberant
ChrisBennet's Avatar
Do you have any info on these "documented inefficiencies" ?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-10-2007, 02:57 PM
Hello Chris,
There are a lot of info in other threads. Lukesportsman provided me with this info:
"You could improve on flow at the intersection of the runners to plenum. Many have argued that the stock TB and opening are restrictive."
as well as:
"If your plumbing your own runners (tubes) into a fabricated plenum, you might consider 180 degree rolled lip trumpets extending into the plenum. There have been studies showing an increase in flow by installing these small trumpets inside a plenum as if exposed to the atmosphere."
These will probably be the biggest changes I will incorporate
Hope this helps,
F.
1979 Porsche 911 SC
Old 01-10-2007, 09:19 PM
Jeff Alton's Avatar
Do yourself a favour and call Steve at rennsportsystems. His number is 503 244 0990. I have talked at length with him about various intake systems and their applications. If I knew then what I know now I would not have went with the basic jenvey set up I posted pics about in one of your previous threads.
Call and ask him about some of the options, you will be glad you did.
Cheers
www.turn3autosport.com
Old 01-10-2007, 10:44 PM
I dropped Steve an email, no reply yet...
Anyone willing to do the measurements for me please? This would help me determine cost/effort involved reproducing the 964 intake manifold vs. some sort of ITB setup
1979 Porsche 911 SC
Old 01-12-2007, 10:56 PM
911-32's Avatar
What would you have gone with, Jeff?
Old 01-16-2007, 04:57 AM
shbop's Avatar
I was a bit shocked to hear that myself. Why the change in attitude? What direction would you have gone Jeff?
Jon
Old 01-17-2007, 07:08 AM
