polizei's Avatar
Question Head Temp Sensor question
I have an '87 Carrera on which I'm performing a top-end rebuild. What is the sensor/device which shares a grommet with the Head Temp Sensor? Whatever it is, the rubber insulation on its wire is torn. Is this something that I can just "re-insulate" or does it need to be replaced?
Andy - 1987 911 Carrera Coupe
Old 03-18-2008, 09:43 AM
Irrationally exuberant
ChrisBennet's Avatar
The head temp sensor, the speed sensor and the reference sensor all share a grommet. If the speed sensor and reference sensors are original (cracked insulation) replace them. I've seen several fail once they are that old. Replace the head temp sensor if it is the single wire kind (1 pin in the connector).
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-18-2008, 04:58 PM
Chris, what are your thoughts on using the BMW equivalent for the speed/reference sensors? Also, aren't they identical to each other?
I know several on the board have used these with no apparent problems and I plan to do the same thing on the rebuild I'm doing on my '88.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-19-2008, 07:17 AM
I've never tried it but I don't doubt it would work.
-Chris
Old 03-19-2008, 12:12 PM
polizei's Avatar
Where can you purchase these sensors? I can't seem to find them on Pelican.
Old 03-19-2008, 12:13 PM
I'm sure Pelican sells them, we just need to confirm the part #. It's simply a BMW speed/ref sensor but happens to work perfectly for the motronic 3.2.
Buck
'88 Coupe, '87 Cab,
Old 03-19-2008, 03:48 PM
safe's Avatar
-Chris
What's the problem with the single wire sensor?
Magnus
Old 03-20-2008, 02:36 AM
polizei's Avatar
Does anyone know the part number for the speed sensor?
Old 03-26-2008, 05:40 AM
It grounds through the head and for some reason this ground path fails (I guess) making it look like infinite resistance/open circuit. The "new" (probably been around 10-15years) sensor has a 2nd wire for the ground.
-Chris
Old 03-26-2008, 06:52 AM
