I have an '87 Carrera on which I'm performing a top-end rebuild. What is the sensor/device which shares a grommet with the Head Temp Sensor? Whatever it is, the rubber insulation on its wire is torn. Is this something that I can just "re-insulate" or does it need to be replaced?
Andy - 1987 911 Carrera Coupe |
Irrationally exuberant
The head temp sensor, the speed sensor and the reference sensor all share a grommet. If the speed sensor and reference sensors are original (cracked insulation) replace them. I've seen several fail once they are that old. Replace the head temp sensor if it is the single wire kind (1 pin in the connector).
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chris, what are your thoughts on using the BMW equivalent for the speed/reference sensors? Also, aren't they identical to each other?
I know several on the board have used these with no apparent problems and I plan to do the same thing on the rebuild I'm doing on my '88.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
-Chris
Where can you purchase these sensors? I can't seem to find them on Pelican.
I'm sure Pelican sells them, we just need to confirm the part #. It's simply a BMW speed/ref sensor but happens to work perfectly for the motronic 3.2.
What's the problem with the single wire sensor?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Does anyone know the part number for the speed sensor?
It grounds through the head and for some reason this ground path fails (I guess) making it look like infinite resistance/open circuit. The "new" (probably been around 10-15years) sensor has a 2nd wire for the ground.
-Chris
