1972_911T's Avatar
3.2 Stroke
When porsche increased capacity from 3.0 to 3.2 why did they increase the stroke to do this rather than cylinder diameter? Was it simply so they could get away without twin plugging the 3.2's? or is there another advantage to the longer stroke of the 3.2 crank?
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 01-30-2007, 01:42 AM
More lower end torque.
Keith Epperly
87 slant nose turbo loook carrera cabriolet
Old 01-30-2007, 06:59 AM
Jeff Alton's Avatar
They already had the crank dimensions and they also had the rods. The rods are 3.3 turbo rods and the crank is the same stroke.
Cheers
www.turn3autosport.com
Old 01-30-2007, 03:11 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Cheers
Jeff is right..the 3.2 crank and rods and the 930 3.3 crank and rods are the identical parts (3.3 crank had been around since at least as far back as '78), however the distributor drive gear fitted to the crank was different depending...3.3, Clockwise (CW), 3.2, CCW
Scott Kinder
kindersport @ gmail.com
Old 01-30-2007, 08:38 PM
