304065's Avatar
Is this head salvage or scrap?
Looks like somebody got a little excited with the bead blaster.
Seriously, any use for this 2,0 head? Or is it a paperweight?
All three photos are the same, just different zoom and flash.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-20-2007, 06:35 PM
Super Moderator
cstreit's Avatar
Bead Blaster? Are you serious? Looks more like a shotgun blast...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-20-2007, 06:58 PM
E-85 sippin drunk
turbobrat930's Avatar
I am sure you could knock out the valve seat, reweld the head, machine, and replace the valve seat.....
I would not, however, run it like that.....
That almost looks like corrosion...not a bead blaster...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 03-20-2007, 07:01 PM
id911T's Avatar
It's corrosion that has been removed by the bead blast. I had some like that on the outside of my intake manifolds. The corrosion is pretty soft, so the beads blast it right out of the crevasses. Honestly, in a pinch you could run it, but if its a common head, I'd try to source a new one.
Stephen
GruppeB #906
1970 911T
Old 03-20-2007, 07:26 PM
I would say weld and remachine, then cryo. Should be as close to new as you are going to get on a 30+ y/o head.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 03-20-2007, 10:20 PM
304065's Avatar
That's what I thought. As you can see from the casting number, this corrosion is on the exhaust side. The engine probably sat with water in it for a long time, and then when the heads were bead-blasted, it all eroded. Only two out of the six heads in this set are usable, but I got them for next to nothing. This one is a paperweight.
Noah, there are many applications for JB weld ranging from periodontia to birth control; this ain't one.
'81 R65
Old 03-21-2007, 06:35 AM
A BIG "amen" to that,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-21-2007, 11:33 PM
Grady Clay's Avatar
[i]This one is a paperweight.[/B]
+1
You should be able to easily find this head. With some effort you might be able to match the date.
That corrosion is from water and other combustion products sitting there.
The risk is the corrosion found its way around and under the valve seat. This reduces the heat transfer and the interference fit of the seat in the head. If you want to see real carnage, look at an engine that has "dropped a seat."
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-22-2007, 01:18 PM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
John,
That is NOT a paperweight!!!
Obviously you have never seen a trot line weight....
Man, is that worth bringing back? I'd think the cost of replacing the 30 year old part would be more than the cost of repairing it, if the repair is possible with a reasonable amount of certainty...
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 03-25-2007, 08:25 AM
