964 Case - Timesert or Case Savers?
I'm thinking that Timeserts might be preferable to the Case Saver on the aluminum case. 4 studs removed so far. 2 were pulled. Any advice based on your experience?
Thanks!
Steve '89 Carrera 4 |
Wondering if there's any preference? Timeserts seem preferable due to the shoulder, which case saver doesn't have, and the finer threads for aluminum.
Anyone have any experience?
Try not, Do or Do not
CaseSavers are always preferred because of their course threads. The lip has little or no value in this application.
CaseSavers are also made of steel and Timeserts are make of some sort of soft alloy. Timesert is making a stainless insert now but the fine threads are still an issue. That said, either will work.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks, Henry. I understand that logic with respect to the old mag cases, which, I believe, are considerably softer than the newer aluminum cases. I am concerned about the differences between the mag and aluminum case like in the 964.
Constitutional Liberal
No need to be concerned. The logic holds true for aluminum as well as mag. Course threads hold best in soft materials.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Steve:
Case Savers, only. Thats all we use on Magnesium and the rare Aluminum case that needs such things,.......
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Where can you get Case Savers?
'77 911S w/'81 3.0/MegaSquirt/MSD '81 911SC stock |
Riddle Machine Company AKA RIMCO
714-549-0357 * Ask for automotive counter , then Todd
Henry,
I just got the case savers from the above address and the case savers seem to have a finer thread pattern than the timeserts. Do you drill a 7/16 hole and tap with a 1/2 20?
do the drilling and tapping in a mill, NOT by hand!!! (just in case you were thinking about doing it that way).
John,
I plan on having a machine shop do it, are my drill and tap numbers right?
