Eye of the Toiger
MFI 2.7 Vs 3.0 78 SC motor do I, don't I
I'm at cross roads, my 74 2.7 911s needs motor needs a rebuild
Option 1. - Rebuild my 2.7 I have access to a Complete MFI set-up from a friend pump completely rebuilt by bosch in Germany, everything in good condition set up for a 2.7RS I have a set of DC 60's, JE pistons (still have to buy) titainium retainers and double value springs etc.. all the bits to make a screamer (but I have a mag case) Option 2. - buy a 3.0 and build my 2.7 at my leasure A guy I know has a 3.0 911 sc engine (78) in good working order (180 hp model) $5K Aussie and I can build my 2.7 screamer at my leasure. I have ssi's and an m&k 2in 2out (which is a great exhaust) Not sure which way to go what do you guys think I should do????
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo Last edited by matty74; 04-17-2007 at 02:02 AM.. |
Slumlord
If you want to drive your car anytime soon buy the 3.0.
I rebuilt my 2.7 myself, but it took months and months as I found more and more things that needed repair. An old 2.7 rebuild is not a weekend job.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Eye of the Toiger
Yeah, you're right, the 3.0 is being leakdown & compression tested and checked for broken studs, I'll throw that in so I can drive it and build a bastard out of the 2.7, or better fix the 2.7 throw it back in and build a bastard out of the 3.0
I have also aquired a complete MFI set up minus the injectors and lines from a guy I know who lives near me. I is from a 911s and the pump has been rebuilt by bosch in Germany (with recipts) for a 2.7 RS, it is in perect condition 36mm throttle bodies. Can't wait.
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
