Eye of the Toiger
Max Mortiz pistons 3.0 - 3.2
Does anyone know anything about Max Mortiz pistons. The pistons take a 3.0 tp 3.2 but I'm not sure what compression ratio
does anyone know? Matt
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
They are 9.3 to 1. I have a unused set, ceramic coated.
Eye of the Toiger
what type of cam can I use with these DC 40, DC 60 ?
what sor of config are you running? and HP?
Matt,
I did not use the Max Moritz due to a change in build plans so I dont have any data for you. I switched to MFI so went with a MFI p&c from Andial. I still have the MM p&c on the shelf. Bob |
Eye of the Toiger
Can you use MFI with these I read that they can't take too agressive cam shaft
Not the optimum for MFI, that is why I changed, plus a bump in CR. CIS will not take much overlap.
Eye of the Toiger
Bruce Andersen states that with the MM pistons a GE40 or an S cam will give significant power increase used with webers.
Now I have DC60 and MFI, because of the overlap on S cams or modified S in my case Bruce reckons that Additional valve clearance is required, does he mean machining the pistons to get the required valve clearance?
max moritz pistons
46mm webers, max moritz pistons ge80 camshafts=
370 hp 260 torque |
Re: max moritz pistons
max moritz pistons
Look at the graph in bruce anderson's book 911 performance
370hp |
were both wrong, on page 152 the chart shows about 330hp, 260lb/ft. the pic below is of my mahle 98mm piston/cylinders. the top is a dome type for carbs or mfi, the CR is 9.5:1. the valve pockets were plenty deep for DC62 cams, i'm sure a GE80 would work also. hope this helps.
These are the Mahle 98mm 10.3:1 for MFI.
Jon 911 #303129 81' SC project 70 SS 454 El Camino |
