911quest's Avatar
Crank combo question
Hey guys can you use a 70.4 crank with 2.2S P/C with no major piston to valve issues? Also is the 2.2S MFI tunable to this configuration or will pump have to readjusted to suit the motor?
I'm also building this on a early 2.0 aluminum case will there be any other major problems with this set up?
Tony Proasi
1969S
1957 VW Pickup
Old 05-19-2007, 05:40 AM
MBEngineering's Avatar
HI 911quest, yes piston to crankcase clearance, do a assembly check with all the parts you will be using to check clearances.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 05-19-2007, 08:07 AM
What Mike is talking about is that the pistons bottoms will likely hit the case. This problem can be machined away (on the case not the pistons).
-Andy
Old 05-19-2007, 09:48 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
You'll also need to weld a mount onto the alum case for the MFI pump .. 2.2S pump can run a 2.4 S spec. without issue, just richen it.
Scott Kinder
kindersport @ gmail.com
Old 05-20-2007, 08:01 PM
911quest's Avatar
Thanks guys that was what I was thinking but just wanted to make sure before I jumped in with both feet.
Tony Proasi
1969S
1957 VW Pickup
Old 05-20-2007, 08:09 PM
