Loose nut bhind the wheel
MFI twin plug tin mods Cyl #3
What do you guys do to modify the tin @ #3 on the lower plug. With the tin from factory there is a half circle from machining the lower cover that is not large enough to get the wire end through. As I see it the tin can be hammered out slightly, or cut away enough tin to fit, or cut away and weld a 1/2 circle piece of tin to complete the access hole. Bear in mind that the pump belt cover is a factor in this as well. Solution with pics if possible would be helpful. Thanks.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 05-08-2007, 09:25 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Here is a simple way to deal with this issue.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-09-2007, 09:31 AM
Thanks Henry,
Looks like a wooden form and a hammer will do that. I tried to post a picture but the system would time out before it loaded.
Ed
1974 260Z SCCA ITS
1998 M3
Old 05-09-2007, 10:35 AM
