distributor cap grease
Anyone,,,, do you use dielectric grease in the rotor cap and on rotor tip? Thanks in advance !!
Old 05-22-2007, 11:57 AM
304065's Avatar
No, you use grease on the rubbing block for the points. "Dielectric" means it does not conduct electricity, so you would not want to use it on anything that is intended to conduct, like the rotor.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-23-2007, 06:16 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If you live in an area that tends to be wet you can use dielectric grease around the base of the distributor cap where it sits on the distributor. This will help to seal out moister.
It is also good if you wash your engine often. Remember it will help, it won't prevent all the water from getting in.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-23-2007, 01:03 PM
Thank you very much for the information,,,, Lenny
Old 05-24-2007, 12:11 PM
