Eye of the Toiger
What can I use to plug the polution holes on my heads?
I have had a 3.0 litre 78 sc motor rebuilt without the polution gear.
The heads have holes next to the exhaust ports and I need them pluged. What is the best way to plug these holes? cheers Matt
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Less brakes, more gas!
I think I used Mercedes plugs... like tranny plugs... You can use set screws or regular machine screws. I think I used the copper never seize on them and they never fell out. Iactually think I bought them here.... lets see... searching we find:
air injector plug size Air injection Hunh... 914 rear caliper thingamajiggers it seems... or your best ACE or Lowes 10.0 x 1.0 plugs work. and the how too: Stupid guide of fitting emmision plugs in three steps... Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Matt,
Those are the correct items. The thread is a bit strange and given the cost of heads and downtime I'd spend the money on the right items. They come with a copper washer and should stay for good. I had some other ones in my race motor and had one fall out. J
1985.5 944 GTS |
Guest
Posts: n/a
The holes are fine thread and you can use the screw in plugs. I'm in the process of doing the same thing on my 2.0 914 engine. Those are deeper in and I got some fine tread bolts. Just make sure you don't thread them in too far. A nut can be used for a distance stop on them.
Weltmeister has a kit for this now. I don't see it on PP web site but they can probably get it for you.
Robert Currently Porsche less (but the wife has 2) |
Insane Dutchman
How about retapping the holes and fitting either exhaust temperature probes?
Dennis
1975 911S with Kremer 3.2 1989 911 Carrera Project Car |
