Cold compression test
Hi
I know that a compression test should be done on a warm engine, but yesterday I did one for the first time when I changed my plugs, see thread sparkplug reading help. But does a cold test have any value? I got some pretty lousy results (I'm at sea level): #1 110 psi #2 140 #3 140 #4 120 #5 142 #6 110 Then I put some oil in the cylinders #1 130 #2 150 #3 150 #4 135 #5 145 #6 142 But I don't know if the oil sealed bad rings or just a cold engine, do I? And yes, I should probably perform a proper leak down test.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Air Medal or two
Why not do a hot comp. test ????
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Convenience, I had all plugs removed...
