mnmasotto's Avatar
Help with oil consumption and leak down test results
I have a 1987 3.2 carrera with 75K original miles. The car has been extremely well cared for and never had any engine work. The car has been driven appropriately(no short trips) it whole life. The car has always had Valvoline 20-50W, changed every 3000 miles, until 50K when the preferred oil was swiched to Mobile 1 15-50W.
Recently the car has been using about one quart of oil every 750-800 miles. The car never, every smokes, even on start up!!!!!!!!! The car has no oil leaks. My mechanic (very well respected local air cooled Porsche specialist) said the plugs always look great!!! The car runs absolutely fantastic. The car has never been abused, raced or tracked. A recent leak down test was between 2-4% on all cylinders. A second opinion said that he was not sure what the culprit was? valve seals, ring?? He recommended a valve job and new rings (assuming the P & C's measure within tolerances)
Question number 1) Do I need to do anything? I do not mind spending the money on a new engine if it is really needed, but is it needed or is this normal for a 3.2 with 75K?
Question number 2) What could happed if I just drive it until is gets worse?
Question number 3) If I refer to the factory Porsche manual this is within normal limits??? However, others with recently rebuilt engines use much less oil. Who do I trust?? A local mechanic has looked at the data and says just drive it!!!
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 07-17-2007, 08:54 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Re: Help with oil consumption and leak down test results
Sounds like valve guides.
Originally posted by mnmasotto
.....edit......
Seems pretty normal.
nothing horrible.
I agree, DRIVE IT and start saving for at least a top end
BTW: Where is ORANGO County?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-18-2007, 07:35 AM
OldTee's Avatar
My suggestion is to drive it hard. At the next oil change get rid of the Mobil 1 and go back to the Valvoline oil. New filter too.
Old Tee
all 911s sold
Old 07-18-2007, 08:52 PM
mnmasotto's Avatar
Update after engine tear down
The engine was taken apart this weekend. The valve guides were shot! The Pistons and Cylinders were in great shape. The cam lobes had some pitting. I am not sure if I should complete the valve job or buy bigger P&C's (3.4). The cylinders are Allusil. If I re-use my current 3.2 P&C's do I use the same rings or new ones??
2007 997 GT3 - SOLD
Old 07-27-2007, 10:11 PM
Sounds like all you need is a valve job. If you keep the old pistons and cylinders you can probably re-use the rings. I've had good luck with that on two engines where the rings weren't worn out. You need to measure the old rings and ring lands or have your shop do it. The bigger pistons and cylinders are nice but do you want to spend that much when your old set is good?
-Andy
Old 07-28-2007, 01:54 PM
