7R Block clean, clean,clean question
I took all studs out of the block and wonder what sandpaper is appropiate for
cleaning the saeling surfaces to match with the three bond spec. I 600 paper sufficient. Surface gets very clean but does three bond need rougher surface than 600. What's your experience. bob
During my rebuild, I have used only Scotchbrite pads on all my sealing surfaces. For my case halves, I used the pads, along with brake cleaner, and the surfaces came out very clean, and not scratched.
I would probably stay away from any sandpaper, which would leave scratches in the metal, and keep from obtaining a tight seal. Scott |
I've been told by the local experts to only seal the case perimeter surfaces and not the internal surfaces like the bearing saddles.
I know this is different that what is recommended in Wayne's book but I was told that sealant on the bearing saddles might cause those critical surfaces to not mate properly.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Super Moderator
Gasket cleaner and scotchbrite pads are sufficient. I wouldn't use any harsher abrasive...
You may have to block sand the area where the case studs have the tendency to pull. The 2 long perimeter studs on the front below #8 main. The two #8 studs and the long intermediate shaft stud. All of these really need time-certs to prevent them from pulling in the future.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
I use 400 grit on a long flat bar. Once you see minor scratches on the area of the perimeter seam that has not been affected you will be around .0005 from being true. I like to stop right around this point as you will quickly lose your reference point.. Do a quick touch up with 600 grit and your good. I do this before I have time-certed these areas but It can be done after but make sure the time-certs will not stand proud of the reconditioned surface
thanks burn bros,
do you mean these bolts. ![]() Greetings bob |
Guys,
Keep in mind there are two different home-use Scotch-Brite pads; the green Heavy Duty version and the blue All-Purpose version. The Heavy Duty is an abrasive pad and isn’t appropriate for the sealing surfaces. With care, the All-Purpose can be lightly used with lacquer thinner or brake clean. There are industrial versions of Scotch-Brite pads used in the auto body industry and others. These are inappropriate for case sealing surfaces. I like finding the correct solvent for whatever type sealant was previously used and use the least abrasive wipe. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Bob,
The two on the right that you have circled are not the ones, the other three that you have circled are correct All the studs are on the left side of the picture. The # 8 main bearing is the large aluminum cylinder that the front seal mounts into. Those studs that are immediately above and below it are the last two problem studs.
Are we takling about the studs around the 8 bearing. See picture ?
Greetings Bob
Yup Yup!
