HKZ Bob's Avatar
7R Block clean, clean,clean question
I took all studs out of the block and wonder what sandpaper is appropiate for
cleaning the saeling surfaces to match with the three bond spec.
I 600 paper sufficient. Surface gets very clean but does three bond need rougher surface than 600.
What's your experience.
bob
Old 08-19-2007, 04:29 AM
Send a message via AIM to smessing
During my rebuild, I have used only Scotchbrite pads on all my sealing surfaces. For my case halves, I used the pads, along with brake cleaner, and the surfaces came out very clean, and not scratched.
I would probably stay away from any sandpaper, which would leave scratches in the metal, and keep from obtaining a tight seal.
Scott
Old 08-19-2007, 06:55 AM
I've been told by the local experts to only seal the case perimeter surfaces and not the internal surfaces like the bearing saddles.
I know this is different that what is recommended in Wayne's book but I was told that sealant on the bearing saddles might cause those critical surfaces to not mate properly.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 08-19-2007, 07:27 AM
Super Moderator
cstreit's Avatar
Gasket cleaner and scotchbrite pads are sufficient. I wouldn't use any harsher abrasive...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 08-19-2007, 09:37 AM
BURN-BROS's Avatar
You may have to block sand the area where the case studs have the tendency to pull. The 2 long perimeter studs on the front below #8 main. The two #8 studs and the long intermediate shaft stud. All of these really need time-certs to prevent them from pulling in the future.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-19-2007, 09:48 AM
^^That is very good advice --- sometimes you'll find the area local to a stud to be proud of the flat mating surfaces.
Old 08-19-2007, 10:24 AM
BURN-BROS's Avatar
I use 400 grit on a long flat bar. Once you see minor scratches on the area of the perimeter seam that has not been affected you will be around .0005 from being true. I like to stop right around this point as you will quickly lose your reference point.. Do a quick touch up with 600 grit and your good. I do this before I have time-certed these areas but It can be done after but make sure the time-certs will not stand proud of the reconditioned surface
Burnham Performance
Old 08-19-2007, 11:10 AM
HKZ Bob's Avatar
thanks burn bros,
do you mean these bolts.
Greetings bob
Old 08-20-2007, 09:56 AM
Grady Clay's Avatar
Guys,
Keep in mind there are two different home-use Scotch-Brite pads; the green Heavy Duty version and the blue All-Purpose version. The Heavy Duty is an abrasive pad and isn’t appropriate for the sealing surfaces. With care, the All-Purpose can be lightly used with lacquer thinner or brake clean.
There are industrial versions of Scotch-Brite pads used in the auto body industry and others. These are inappropriate for case sealing surfaces.
I like finding the correct solvent for whatever type sealant was previously used and use the least abrasive wipe.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-20-2007, 12:07 PM
BURN-BROS's Avatar
Originally Posted by HKZ Bob View Post
thanks burn bros,
Greetings bob
Bob,
The two on the right that you have circled are not the ones, the other three that you have circled are correct
All the studs are on the left side of the picture.
The # 8 main bearing is the large aluminum cylinder that the front seal mounts into. Those studs that are immediately above and below it are the last two problem studs.
Burnham Performance
Old 08-20-2007, 12:46 PM
HKZ Bob's Avatar
Are we takling about the studs around the 8 bearing. See picture ?
Greetings Bob
Old 08-21-2007, 07:33 AM
BURN-BROS's Avatar
Yup Yup!
Burnham Performance
Old 08-21-2007, 12:32 PM
